> Watercooling hoses through longs?, I need feedback from those who've done it.
pktzygt
post Mar 24 2012, 07:28 PM
I'm finalizing my Suby conversion and I can seem to make myself put the cooling lines under the car.
I can think of one person (Britain) who has put the cooling hoses in the longs, but I was hoping to get some feedback on the difficulty of installation and how well it works form some suby or V8 guys. Part of the problem is that I haven't ever cut into the longs myself.
One one hand I don't want to put extra heat in the cabin or lose foot space but on the other, I hate the shortcut look of the under car routing.
Do the bends in the hose cause cooling issues?
Can the hoses go into the longs without taking foot space?
Should I put them under the car and re-route them as a future winter project?
Thanks!
ruby914
post Mar 24 2012, 08:02 PM
QUOTE(pktzygt @ Mar 24 2012, 06:28 PM) *
Thanks!
I tried and gave up quickly. I ran mine under the car. That was just too easy at the time. I don't recall my hose OD. Think smaller would be easier.
What ID, OD is your hose?
I am still thinking of a way over the jack post, out side of the long.
pktzygt
post Mar 24 2012, 08:07 PM
QUOTE(ruby914 @ Mar 24 2012, 10:02 PM) *
I am using those NAPA yellow stripe that Renagade uses. I think it was 1 1/2" and 1" ID. I'll get the measurements on them next time I go out to the garage.
ruby914
post Mar 24 2012, 11:49 PM
QUOTE(pktzygt @ Mar 24 2012, 07:07 PM) *
Just checked my hose, ~1.2 ID 1.6 OD. Green stripe I think.
I don't think it needs to be so big.
pktzygt   Watercooling hoses through longs?   Mar 24 2012, 07:28 PM
ruby914   I'm finalizing my Suby conversion and I can s...   Mar 24 2012, 08:02 PM
pktzygt   I tried and gave up quickly. I ran mine under the...   Mar 24 2012, 08:07 PM
ruby914   I tried and gave up quickly. I ran mine under th...   Mar 24 2012, 11:49 PM
v82go   Another option is aluminum conduit (under the car)...   Mar 25 2012, 10:05 AM
pktzygt   Another option is aluminum conduit (under the car...   Mar 25 2012, 10:30 AM
ruby914   Another option is aluminum conduit (under the car...   Mar 25 2012, 12:32 PM
McMark   Here is what's inside.   Mar 25 2012, 11:06 AM
pktzygt   Here is what's inside. Thanks Mark! Exa...   Mar 25 2012, 11:45 AM
kg6dxn   Project Anklebiter has them in the longs. My firs...   Mar 25 2012, 11:35 AM
pktzygt   Aluminum through the tunnel may be a better optio...   Mar 25 2012, 11:51 AM
pktzygt   WOW, that aluminum tubing isn't expensive at a...   Mar 25 2012, 11:58 AM
J P Stein   Brit followed the same path as set up for oil cool...   Mar 25 2012, 11:47 AM
pktzygt   Brit followed the same path as set up for oil coo...   Mar 25 2012, 12:03 PM
DBCooper   You can also search for Rod Simpson V8 conversions...   Mar 25 2012, 12:42 PM
pktzygt   You can also search for Rod Simpson V8 conversion...   Mar 25 2012, 12:55 PM
kwales   :blink: Seriously, a couple of things to cons...   Mar 25 2012, 03:54 PM
ruby914   :blink: Seriously, a couple of things to con...   Mar 25 2012, 04:19 PM
Cracker   As a rule...you do not want exposed "hard...   Mar 25 2012, 04:34 PM
ruby914   As a rule...you do not want exposed "hard...   Mar 25 2012, 04:36 PM
pktzygt   :blink: Seriously, a couple of things to con...   Mar 25 2012, 06:09 PM
DBCooper   But yes, it can make a difference How much differ...   Mar 25 2012, 07:57 PM
pktzygt   But yes, it can make a difference How much diffe...   Mar 25 2012, 08:44 PM
Cracker   Yeah, this was the dilemma I faced too when decidi...   Mar 25 2012, 01:54 PM
pktzygt   Yeah, this was the dilemma I faced too when decid...   Mar 25 2012, 03:16 PM
bulitt   Ferrari 308's 328's, 512bbi's have alu...   Mar 25 2012, 02:15 PM
dlo914   Why not route them behind the rocker panels? Ive s...   Mar 25 2012, 03:24 PM
BMITCHELL   mine, never got around to puting the rockers on.   Mar 25 2012, 03:50 PM
ruby914   mine, never got around to puting the rockers on. ...   Mar 25 2012, 04:25 PM
ruby914   The front is harder. Only after I replaced this lo...   Mar 25 2012, 04:34 PM
ruby914   Here is the headache bend that needs to clear the ...   Mar 25 2012, 04:51 PM
kg6dxn   At this point, you should go up and into the top o...   Mar 25 2012, 04:57 PM
skeates   I'm in the process of doing a suby conversion ...   Mar 25 2012, 08:46 PM
pktzygt   Ohh yeah, I forgot to mention. A/C isn't posh ...   Mar 25 2012, 09:00 PM
pktzygt   Yeah, Skeates. I'm not too worried about the c...   Mar 25 2012, 09:10 PM
Cracker   Yeah, Skeates. I'm not too worried about the ...   Mar 26 2012, 06:51 AM
kg6dxn   This craigs list car has someone's attempt at ...   Mar 25 2012, 09:16 PM
Andyrew   ^^ What a great way to heat up the fuel. Pretty ...   Mar 25 2012, 10:32 PM
pktzygt   ^^ What a great way to heat up the fuel. Pretty...   Mar 26 2012, 06:56 AM
bulitt   Has anyone used rectangular tubing on the bottom? ...   Mar 26 2012, 04:56 AM
kg6dxn   Has anyone used rectangular tubing on the bottom?...   Mar 26 2012, 11:51 AM
kwales   Has anyone used rectangular tubing on the bottom?...   Mar 26 2012, 12:37 PM
rohar   This is the next project for my Audi conversion an...   Mar 26 2012, 07:42 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:20 PM
