> Watercooling hoses through longs?, I need feedback from those who've done it.
pktzygt
post Mar 24 2012, 07:28 PM
I'm finalizing my Suby conversion and I can seem to make myself put the cooling lines under the car.
I can think of one person (Britain) who has put the cooling hoses in the longs, but I was hoping to get some feedback on the difficulty of installation and how well it works form some suby or V8 guys. Part of the problem is that I haven't ever cut into the longs myself.
One one hand I don't want to put extra heat in the cabin or lose foot space but on the other, I hate the shortcut look of the under car routing.
Do the bends in the hose cause cooling issues?
Can the hoses go into the longs without taking foot space?
Should I put them under the car and re-route them as a future winter project?
Thanks!
pktzygt
post Mar 25 2012, 09:10 PM
Yeah, Skeates. I'm not too worried about the cooling capacity with the subaru motor and the renegade cooling. I've never heard any issues with this setup unless someone screwed something up like swapping the inlet and outlet hoses.
I'm not going to cut open my longs for much more than getting the hose in the front of the long. Have you seen the threads where the door gaps get messed up. I'm not opening that can of worms. I'm hesitant to even put an engman kit on it.....yet.....
pktzygt   Watercooling hoses through longs?   Mar 24 2012, 07:28 PM
ruby914   I'm finalizing my Suby conversion and I can s...   Mar 24 2012, 08:02 PM
pktzygt   I tried and gave up quickly. I ran mine under the...   Mar 24 2012, 08:07 PM
ruby914   I tried and gave up quickly. I ran mine under th...   Mar 24 2012, 11:49 PM
v82go   Another option is aluminum conduit (under the car)...   Mar 25 2012, 10:05 AM
pktzygt   Another option is aluminum conduit (under the car...   Mar 25 2012, 10:30 AM
ruby914   Another option is aluminum conduit (under the car...   Mar 25 2012, 12:32 PM
McMark   Here is what's inside.   Mar 25 2012, 11:06 AM
pktzygt   Here is what's inside. Thanks Mark! Exa...   Mar 25 2012, 11:45 AM
kg6dxn   Project Anklebiter has them in the longs. My firs...   Mar 25 2012, 11:35 AM
pktzygt   Aluminum through the tunnel may be a better optio...   Mar 25 2012, 11:51 AM
pktzygt   WOW, that aluminum tubing isn't expensive at a...   Mar 25 2012, 11:58 AM
J P Stein   Brit followed the same path as set up for oil cool...   Mar 25 2012, 11:47 AM
pktzygt   Brit followed the same path as set up for oil coo...   Mar 25 2012, 12:03 PM
DBCooper   You can also search for Rod Simpson V8 conversions...   Mar 25 2012, 12:42 PM
pktzygt   You can also search for Rod Simpson V8 conversion...   Mar 25 2012, 12:55 PM
kwales   :blink: Seriously, a couple of things to cons...   Mar 25 2012, 03:54 PM
ruby914   :blink: Seriously, a couple of things to con...   Mar 25 2012, 04:19 PM
Cracker   As a rule...you do not want exposed "hard...   Mar 25 2012, 04:34 PM
ruby914   As a rule...you do not want exposed "hard...   Mar 25 2012, 04:36 PM
pktzygt   :blink: Seriously, a couple of things to con...   Mar 25 2012, 06:09 PM
DBCooper   But yes, it can make a difference How much differ...   Mar 25 2012, 07:57 PM
pktzygt   But yes, it can make a difference How much diffe...   Mar 25 2012, 08:44 PM
Cracker   Yeah, this was the dilemma I faced too when decidi...   Mar 25 2012, 01:54 PM
pktzygt   Yeah, this was the dilemma I faced too when decid...   Mar 25 2012, 03:16 PM
bulitt   Ferrari 308's 328's, 512bbi's have alu...   Mar 25 2012, 02:15 PM
dlo914   Why not route them behind the rocker panels? Ive s...   Mar 25 2012, 03:24 PM
BMITCHELL   mine, never got around to puting the rockers on.   Mar 25 2012, 03:50 PM
ruby914   mine, never got around to puting the rockers on. ...   Mar 25 2012, 04:25 PM
ruby914   The front is harder. Only after I replaced this lo...   Mar 25 2012, 04:34 PM
ruby914   Here is the headache bend that needs to clear the ...   Mar 25 2012, 04:51 PM
kg6dxn   At this point, you should go up and into the top o...   Mar 25 2012, 04:57 PM
skeates   I'm in the process of doing a suby conversion ...   Mar 25 2012, 08:46 PM
pktzygt   Ohh yeah, I forgot to mention. A/C isn't posh ...   Mar 25 2012, 09:00 PM
pktzygt   Yeah, Skeates. I'm not too worried about the c...   Mar 25 2012, 09:10 PM
Cracker   Yeah, Skeates. I'm not too worried about the ...   Mar 26 2012, 06:51 AM
kg6dxn   This craigs list car has someone's attempt at ...   Mar 25 2012, 09:16 PM
Andyrew   ^^ What a great way to heat up the fuel. Pretty ...   Mar 25 2012, 10:32 PM
pktzygt   ^^ What a great way to heat up the fuel. Pretty...   Mar 26 2012, 06:56 AM
bulitt   Has anyone used rectangular tubing on the bottom? ...   Mar 26 2012, 04:56 AM
kg6dxn   Has anyone used rectangular tubing on the bottom?...   Mar 26 2012, 11:51 AM
kwales   Has anyone used rectangular tubing on the bottom?...   Mar 26 2012, 12:37 PM
rohar   This is the next project for my Audi conversion an...   Mar 26 2012, 07:42 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:20 PM
