> Watercooling hoses through longs?, I need feedback from those who've done it.
pktzygt
post Mar 24 2012, 07:28 PM
I'm finalizing my Suby conversion and I can seem to make myself put the cooling lines under the car.
I can think of one person (Britain) who has put the cooling hoses in the longs, but I was hoping to get some feedback on the difficulty of installation and how well it works form some suby or V8 guys. Part of the problem is that I haven't ever cut into the longs myself.
One one hand I don't want to put extra heat in the cabin or lose foot space but on the other, I hate the shortcut look of the under car routing.
Do the bends in the hose cause cooling issues?
Can the hoses go into the longs without taking foot space?
Should I put them under the car and re-route them as a future winter project?
Thanks!
rohar
post Mar 26 2012, 07:42 AM
This is the next project for my Audi conversion and yes, I'm going through the tunnel. I'm using a cable shifter so I've got a bit more room. Just to add complexity, I'm going right under the fuel tank. The simplicity and straight runs resolve a lot of problems, but as has been mentioned repeatedly heat soak has to be addressed.
I've got a waste oil fueled foundry in the shop. The oil has to be pre-heated to burn efficiently. I normally run it up to about 300 degrees f. Hot oil lines kept burning me when I'd mindlessly bump into them. Somehow the 5' flame comming out the top of it always takes all my attention and I forget about the oil lines. After a couple of years of this, I came up with a semi flexible insulation.
Grab a couple of bags of pearlite from the local garden center. It's cheep, light and a natural low temp refractory (it'll hold up to about 1000F ). On your way home stop by the hardware store and pick up some pure silicone caulk. Put the pearlite in a bucket and add just enough caulk to hold the pearlite beads together and spread in a channel mold covered in cling wrap. Once it's cured, you have a cheep and very effective insulating wrap/tape/mat depending on how you molded it. I'm planning on forming 2 sheets the size of the center console. One on the top of the tubes and one on the bottom. Same under the gas tank.
On the preheated oil lines on the foundry, I can run 300f oil through it for hours and the lines are still cool to the touch.
pktzygt   Watercooling hoses through longs?   Mar 24 2012, 07:28 PM
ruby914   I'm finalizing my Suby conversion and I can s...   Mar 24 2012, 08:02 PM
pktzygt   I tried and gave up quickly. I ran mine under the...   Mar 24 2012, 08:07 PM
ruby914   I tried and gave up quickly. I ran mine under th...   Mar 24 2012, 11:49 PM
v82go   Another option is aluminum conduit (under the car)...   Mar 25 2012, 10:05 AM
pktzygt   Another option is aluminum conduit (under the car...   Mar 25 2012, 10:30 AM
ruby914   Another option is aluminum conduit (under the car...   Mar 25 2012, 12:32 PM
McMark   Here is what's inside.   Mar 25 2012, 11:06 AM
pktzygt   Here is what's inside. Thanks Mark! Exa...   Mar 25 2012, 11:45 AM
kg6dxn   Project Anklebiter has them in the longs. My firs...   Mar 25 2012, 11:35 AM
pktzygt   Aluminum through the tunnel may be a better optio...   Mar 25 2012, 11:51 AM
pktzygt   WOW, that aluminum tubing isn't expensive at a...   Mar 25 2012, 11:58 AM
J P Stein   Brit followed the same path as set up for oil cool...   Mar 25 2012, 11:47 AM
pktzygt   Brit followed the same path as set up for oil coo...   Mar 25 2012, 12:03 PM
DBCooper   You can also search for Rod Simpson V8 conversions...   Mar 25 2012, 12:42 PM
pktzygt   You can also search for Rod Simpson V8 conversion...   Mar 25 2012, 12:55 PM
kwales   :blink: Seriously, a couple of things to cons...   Mar 25 2012, 03:54 PM
ruby914   :blink: Seriously, a couple of things to con...   Mar 25 2012, 04:19 PM
Cracker   As a rule...you do not want exposed "hard...   Mar 25 2012, 04:34 PM
ruby914   As a rule...you do not want exposed "hard...   Mar 25 2012, 04:36 PM
pktzygt   :blink: Seriously, a couple of things to con...   Mar 25 2012, 06:09 PM
DBCooper   But yes, it can make a difference How much differ...   Mar 25 2012, 07:57 PM
pktzygt   But yes, it can make a difference How much diffe...   Mar 25 2012, 08:44 PM
Cracker   Yeah, this was the dilemma I faced too when decidi...   Mar 25 2012, 01:54 PM
pktzygt   Yeah, this was the dilemma I faced too when decid...   Mar 25 2012, 03:16 PM
bulitt   Ferrari 308's 328's, 512bbi's have alu...   Mar 25 2012, 02:15 PM
dlo914   Why not route them behind the rocker panels? Ive s...   Mar 25 2012, 03:24 PM
BMITCHELL   mine, never got around to puting the rockers on.   Mar 25 2012, 03:50 PM
ruby914   mine, never got around to puting the rockers on. ...   Mar 25 2012, 04:25 PM
ruby914   The front is harder. Only after I replaced this lo...   Mar 25 2012, 04:34 PM
ruby914   Here is the headache bend that needs to clear the ...   Mar 25 2012, 04:51 PM
kg6dxn   At this point, you should go up and into the top o...   Mar 25 2012, 04:57 PM
skeates   I'm in the process of doing a suby conversion ...   Mar 25 2012, 08:46 PM
pktzygt   Ohh yeah, I forgot to mention. A/C isn't posh ...   Mar 25 2012, 09:00 PM
pktzygt   Yeah, Skeates. I'm not too worried about the c...   Mar 25 2012, 09:10 PM
Cracker   Yeah, Skeates. I'm not too worried about the ...   Mar 26 2012, 06:51 AM
kg6dxn   This craigs list car has someone's attempt at ...   Mar 25 2012, 09:16 PM
Andyrew   ^^ What a great way to heat up the fuel. Pretty ...   Mar 25 2012, 10:32 PM
pktzygt   ^^ What a great way to heat up the fuel. Pretty...   Mar 26 2012, 06:56 AM
bulitt   Has anyone used rectangular tubing on the bottom? ...   Mar 26 2012, 04:56 AM
kg6dxn   Has anyone used rectangular tubing on the bottom?...   Mar 26 2012, 11:51 AM
kwales   Has anyone used rectangular tubing on the bottom?...   Mar 26 2012, 12:37 PM
rohar   This is the next project for my Audi conversion an...   Mar 26 2012, 07:42 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:26 PM
