> Clunk Diagnosis Help..., Thought it was fixed, but noooo, couldn't be that easy!!
audio_file
post Mar 26 2012, 09:15 AM
1st, a little backstory...
I had a fellow teener drive my 75 2.0 a few weeks back, and he commented that my gear lever was moving waaaay too much when he accelerated/decelerated, like my motor mounts were bad. I used the good Dr's motor mount test method (try lifting the engine with a jack while mount is all bolted up) and found that it wasn't the motor mounts (they held the engine down to the mounting bar just fine) but instead was the transmission mounts that were causing the issue, as the main nuts were barely finger tight, allowing the transmission to move around quite a bit. I tightened them up, and added lockwashers to prevent this from happening again...
BUT NOW, I have a very solid, and quite concerning clunk coming from the passenger rear of the car, ESPECIALLY when I accelerate and decelerate. It seems that the changeing load on the engine/transmission is moving something, but I cant figure out what???!! It really doesn't make any noise when hitting bumps, or changing suspension loading (corners, sudden stops, etc.) ONLY when I push the gas, or let off the gas and let the engine drag slow the car down. I checked the "play" on the axle, doesn't seem extreme. I checked the shock mount, the transmission mount (mustache bar?), the points where the engine bar mounts to the body, etc...
It sounds very solid, not body related, and I'm out of ideas and plan to crawl under her again today to try to figure it out... I'm concerned to the point where I can't drive the car again until I nail this down (literally (IMG:style_emoticons/default/laugh.gif) ) HELP!!
Thanks in advance,
Chris
audio_file
post Mar 26 2012, 10:58 AM
QUOTE(vsg914 @ Mar 26 2012, 09:46 AM) *
Why, yes there are bushings in there, one inner and one outer. They will make a heck of a noise. A rear wheel bearing will also make that noise.
QUOTE(mrbubblehead @ Mar 26 2012, 09:50 AM) *
if it was me, i would definitely check this. get the ass end of the car in the air and grab the insides of the tire and see if you can physically move it. rock it side to side, back and forth. if you cant see or feel anything, maybe remove the lower shock bolt and try it again....
I checked wheel play, it's not the wheel bearing. This trailing arm thing is sounding more and more like the culpret... weird that it developed so suddenly after re-securing the transmission... I would've expected the motor mounts to give up before the trailing arm bushings/bolt-up area.
In any case, its definitely on the short list of things to check out, thanks to everybody for the advice so far!
Chris
mrbubblehead
post Mar 26 2012, 11:01 AM
Twodollardoug
QUOTE(audio_file @ Mar 26 2012, 09:58 AM) *
Chris
right thats what im saying.... if you rock the wheel "assembly" you will see or feel movement in the trailing arm pick up points. its easy to do.....
audio_file   Clunk Diagnosis Help...   Mar 26 2012, 09:15 AM
KELTY360   As many can attest, I'm no expert, but I'l...   Mar 26 2012, 09:28 AM
rgalla9146   As many can attest, I'm no expert, but I...   Mar 26 2012, 09:34 AM
mrbubblehead   trailing arm mount?   Mar 26 2012, 09:33 AM
audio_file   Check the 22mm nuts on the inside and outside of ...   Mar 26 2012, 10:42 AM
mrbubblehead   Check the 22mm nuts on the inside and outside of...   Mar 26 2012, 10:50 AM
vsg914   Why, yes there are bushings in there, one inner an...   Mar 26 2012, 10:46 AM
audio_file   Why, yes there are bushings in there, one inner a...   Mar 26 2012, 10:58 AM
mrbubblehead   Why, yes there are bushings in there, one inner ...   Mar 26 2012, 11:00 AM
mrbubblehead   Why, yes there are bushings in there, one inner ...   Mar 26 2012, 11:01 AM
McMark   Lay on the ground and grab the axle shaft. Abrupt...   Mar 26 2012, 11:42 AM
PeeGreen 914   Was that the noise I heard when you were backing u...   Mar 26 2012, 02:12 PM
audio_file   Was that the noise I heard when you were backing ...   Mar 26 2012, 05:00 PM
PeeGreen 914   I may be able to later tonight. I'll let you k...   Mar 26 2012, 06:19 PM
KELTY360   Was there ever a diagnosis for this? Inquiring min...   Apr 5 2012, 04:13 PM
PeeGreen 914   Yes there was... but he may not want to say :evilg...   Apr 5 2012, 04:23 PM
bulitt   Bowling ball in the trunk? :confused:   Apr 5 2012, 04:33 PM
KELTY360   Bowling ball in the trunk? :confused: Funny yo...   Apr 5 2012, 05:24 PM
- Lo-Fi Version Time is now: 22nd August 2025 - 05:02 AM
