| 914itis |
Mar 23 2012, 03:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Taking the car out for the first time. couldn't make it to 2nd gear as it lost acceleration under load. the car revs fine, but lost acceleration under load at about 2500-3000 rpm. I can feel the lost even when pulling in and out of the driveway.
I reconfirmed timing, Dwell is 47.5 fuel pressure is at 29lbs 2.0 djet |
| TheCabinetmaker |
Mar 26 2012, 12:25 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/beerchug.gif) Now you can (IMG:style_emoticons/default/driving.gif)
ppetion Choke under load Mar 23 2012, 03:47 PM
luskesq I'd double check your ignition (sparkplug) wir... Mar 23 2012, 05:14 PM
ppetion
I'd double check your ignition (sparkplug) wi... Mar 23 2012, 07:50 PM
ppetion Ran a pressure test on mps . I put 15 lbs of press... Mar 23 2012, 10:10 PM
Prospectfarms As I understand how they work, loosing two pounds ... Mar 23 2012, 11:53 PM
vsg914 2 lbs in 5 minutes is acceptable leakage. Have yo... Mar 24 2012, 05:24 AM
walterolin Fuel filter? Crimp in an incoming fuel line? Mar 24 2012, 05:59 AM
wingnut86 I dumped my 1st girlfriend for the very reason you... Mar 24 2012, 12:57 PM
underthetire You set timing, but did you check it? Is it actua... Mar 24 2012, 01:04 PM
ppetion Checked valves and they were a bit off . I adjus... Mar 24 2012, 03:24 PM
ppetion I adjusted my tps to .003 ohms, I checked compress... Mar 24 2012, 08:07 PM
rgalla9146
Taking the car out for the first time. couldn... Mar 24 2012, 08:39 PM
ppetion After a long day with Scott, we went over everythi... Mar 25 2012, 09:00 PM
Prospectfarms :trophy: Mar 25 2012, 09:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th April 2026 - 10:07 PM |
