> Rusted Longs - Mayeur kit will Fix? - can,t add Pics :-(
gbg10000
post Mar 17 2012, 09:42 AM
Hi All-
I bought a project car site unseen. It was a gamble, and it is worse than I imagined.
Passenger Long is very bad (photo) Door will still open and shut but gap is very narrow. Rear Floor will also need replace.
Question, would the Brad Mayeur kit alone fix this??
I know I probably need pictures of other areas, but if I am not interested in engine bay cosmetics or autocross stiffness, would I need other reinforcing components in the hell hole area or inner long areas for a daily driver scenario?
I have never welded before, and will only be able to have the car on jack stands. I envision buying a cheap 120v flux wire welder and trying it myself. I do not need the covered areas to look pretty underneath, but I do need a good safe structure.
Comments, advice and opinions appreciated.
Thank you.
This post has been edited by gbg10000: Mar 17 2012, 10:13 AM
ape914
post Mar 28 2012, 10:25 PM
red locktite
Group: Retired Members
me and a friend ended up scraping one that had simular damage, and transfered the good parts to a better body. Some times they are not worth the fixxing. This one is pretty toasted, sorry.
PS suspension ear looks suspect, if there is rust ozzing from the bottom seams of the ear, it likely has a good deal of rust internally, they are made of about three layers of metal, and the water gets in there and the rust is history. Also if you see signs of bulging of the metal, likely that is caused by rust under the outer layer of metal, forcing the bulge out. Hit the bulges with a hammer, and see if it open ups a hole, no bother if it does, you didn't hurt anything cause it was near ready to fail anyway. if either is the case, failure is forth coming and it should too be replaced.
gbg10000   Rusted Longs - Mayeur kit will Fix? - can,t add Pics :-(   Mar 17 2012, 09:42 AM
abnrdo   :ttiwwp:   Mar 17 2012, 09:44 AM
hot_shoe914   Maybe this will answer your question. From Brad hi...   Mar 17 2012, 09:58 AM
shoguneagle   :birthday3: You have just been born into the ...   Mar 17 2012, 12:34 PM
PanelBilly   You have a lot of work ahead to make this car righ...   Mar 17 2012, 01:11 PM
underthetire   That's bad. But what's up with the l80e a...   Mar 17 2012, 01:30 PM
gbg10000   That's bad. But what's up with the l80e ...   Mar 17 2012, 01:37 PM
veltror   That's bad. But what's up with the l80e ...   Mar 17 2012, 05:56 PM
9146986   It looks like the door is closed in the pic, if so...   Mar 18 2012, 01:07 PM
draganc   buy a local 914 guy lunch and ask for his input - ...   Mar 19 2012, 07:17 PM
r_towle   Yes, brads kit will do the structural job, but you...   Mar 19 2012, 07:25 PM
gbg10000   I am going to expose the hell hole, and the floorb...   Mar 20 2012, 08:36 PM
gbg10000   [quote name='gbg10000' post='1650230' date='Mar 20...   Mar 28 2012, 08:18 PM
SirAndy   Please chime in How good are your welding and met...   Mar 28 2012, 09:00 PM
ThePaintedMan   Wow, the long looks almost exactly like what I got...   Mar 28 2012, 09:23 PM
ape914   me and a friend ended up scraping one that had sim...   Mar 28 2012, 10:25 PM
Vacca Rabite   I love seeing a 914 saved, but this is a parts car...   Mar 29 2012, 04:46 AM
gbg10000   Final photos before I decide to try to save this c...   Apr 12 2012, 06:47 PM
saigon71   The car is fixable...but you have a ton of work ah...   Apr 12 2012, 07:09 PM
SCV   Here's one more vote for spending the extra ca...   Apr 12 2012, 08:07 PM
Krieger   Sorry man, that is a parts car. :barf:   Apr 12 2012, 09:59 PM
kg6dxn   There are always nice rollers on SF Bay Craigs Lis...   Apr 12 2012, 10:18 PM
Germancar-Junkie   If you have some $$$$ to play ...   Apr 13 2012, 05:48 AM
reharvey   I've welded up several rusty 914s and I can as...   Apr 13 2012, 07:45 AM
r_towle   That is a typical northeast car IMHO. If you want ...   Apr 13 2012, 08:19 AM
OllieG   I'm about a year into my first 914 resto..I, l...   Apr 13 2012, 09:41 AM
jcambo7   Why discourage some one from trying to fix it. Fo...   Apr 13 2012, 09:48 AM
- Lo-Fi Version Time is now: 3rd July 2025 - 08:37 PM
