AAR test |
AAR test |
914itis |
Mar 30 2012, 08:22 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I ran the 12v 5 minutes test on my aar. After the 5 minutes, it closes but still allow very small amount of air to go by. Is that normal ?
Prospectfarms |
Mar 30 2012, 09:21 PM
Member Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
Get it to operating temp and clamp the hose between AAR and manifold with a needle nose vice-grip.
914itis |
Mar 30 2012, 09:24 PM
DRPHIL914 |
Mar 30 2012, 09:32 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Get it to operating temp and clamp the hose between AAR and manifold with a needle nose vice-grip. And what to look for ? Probably to seal it off and see if it still hunts. If it does you either have a leak somewhere else or your fuel mix is off. |
914itis |
Mar 30 2012, 10:17 PM
Get it to operating temp and clamp the hose between AAR and manifold with a needle nose vice-grip. And what to look for ? Probably to seal it off and see if it still hunts. If it does you either have a leak somewhere else or your fuel mix is off. Where do you adjust the fuel mixture on the djet?? I was reading this article also. and it may be something that I have to live with. http://members.rennlist.com/pbanders/idle.htm |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:09 PM |
