AAR test |
AAR test |
914itis |
Mar 30 2012, 08:22 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I ran the 12v 5 minutes test on my aar. After the 5 minutes, it closes but still allow very small amount of air to go by. Is that normal ?
dangrouche |
Mar 30 2012, 10:28 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
PB blaster plus compressed air, add 12 volts for about 10-minues, AAR should close off while the voltage is applied. The AAR will also get to about 130 degrees (used the HarborFreight infra-red thermometer) let it cool down either in the freezer or workbench, then reapply PB blaster and compressed air, repeat the cycle until the AAR consistently closes using a stopwatch. Yes, I did directly blow into the AAR using clear vinyl tubing. My AAR has always closed off to the point no air passes.
Lo-Fi Version | Time is now: 10th June 2024 - 09:33 PM |
