AAR test |
AAR test |
914itis |
Mar 30 2012, 08:22 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I ran the 12v 5 minutes test on my aar. After the 5 minutes, it closes but still allow very small amount of air to go by. Is that normal ?
Prospectfarms |
Mar 30 2012, 09:21 PM
Member Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
Get it to operating temp and clamp the hose between AAR and manifold with a needle nose vice-grip.
914itis |
Mar 30 2012, 09:24 PM
DRPHIL914 |
Mar 30 2012, 09:32 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Get it to operating temp and clamp the hose between AAR and manifold with a needle nose vice-grip. And what to look for ? Probably to seal it off and see if it still hunts. If it does you either have a leak somewhere else or your fuel mix is off. |
914itis |
Mar 30 2012, 10:17 PM
Get it to operating temp and clamp the hose between AAR and manifold with a needle nose vice-grip. And what to look for ? Probably to seal it off and see if it still hunts. If it does you either have a leak somewhere else or your fuel mix is off. Where do you adjust the fuel mixture on the djet?? I was reading this article also. and it may be something that I have to live with. http://members.rennlist.com/pbanders/idle.htm |
DRPHIL914 |
Mar 31 2012, 02:35 AM
Get it to operating temp and clamp the hose between AAR and manifold with a needle nose vice-grip. And what to look for ? Probably to seal it off and see if it still hunts. If it does you either have a leak somewhere else or your fuel mix is off. Where do you adjust the fuel mixture on the djet?? I was reading this article also. and it may be something that I have to live with. http://members.rennlist.com/pbanders/idle.htm Idle mix can be made richer with the idle screw on top of the e.c.u. Clockwise is richer. If it is lean it will hunt. If you increase the idle speed with the idle valve on the throttle body the hunt may go away. It has been my experience with my d-jet that the mps was out if spec and set too lean, or on one occasion going bad ad was too lean. Some here will say as the book says that it is supposed to default rich and I have had that too one one occasion but then twill not hunt, and you would have a low idle, also lots if soot on the plugs and tailpipe. .you should run more on the rich rather than lean. But I digress. Has your mps been tested for leak? And can you tell if it has been opened up? ? Look and see if the epoxy plug has been removed. If so it has been at some point adjusted and may be set too lean. Che k those things an let me know what you find. But try the e.c.u. idle adjust. And make sure the hose to the aar is not sucking any air. If you have not gotten it to close yet , you can just block off the hose for now after it is warmed up ans previously suggested. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:12 AM |
