| Black914_4 |
Apr 1 2012, 02:09 PM
Member ![]() ![]() Group: Members Posts: 272 Joined: 11-January 12 From: AR Member No.: 13,994 Region Association: South East States |
Stock '74 2.0
How much pressure does the injector need to work properly? I know the fuel reg is set about 29 psi. |
| Tom |
Apr 1 2012, 06:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
The fuel pump shood turn off if the engine dies. That is why the ECU controls the ground to the fuel pump relay. It turns the fuel pump on at three times
1- upon initial key to on, for about 1.5 seconds 2 whenever the starter is engaged - key switch to start. 3- when the engine is exceeding X RPM's The design is for the fuel pump to shut off if the engine stops for some reason. Be careful here as an engine problem due to leaking fuel lines will cause the engine to run poorly or stop. You don't want the fuel pump running if there is a leak. Tom |
2xs performance Fuel Injector question. Apr 1 2012, 02:09 PM
vsg914 Hmmm, not sure, but since the specified pressure i... Apr 1 2012, 02:23 PM
2xs performance The regulator lets fuel by and keeps system at lea... Apr 1 2012, 02:35 PM
orange914
But to keep the pump from running full time and c... Apr 1 2012, 08:50 PM
type47 I'm not sure about the idea that the "pum... Apr 1 2012, 03:25 PM
vsg914 What Jim said. The pump runs for a half second whe... Apr 1 2012, 03:30 PM
Dave_Darling That's correct, the pump just runs continuousl... Apr 1 2012, 03:31 PM
2xs performance
What Jim said. The pump runs for a half second wh... Apr 1 2012, 03:56 PM
brant Thats why the factory has a return line...
make su... Apr 1 2012, 04:33 PM
2xs performance return line works fine.
The factory wires are st... Apr 1 2012, 06:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 20th March 2026 - 03:37 AM |
