> Curil K2 when will it dry?, Hardening time?
larss
post Apr 4 2012, 08:41 AM
Used Curil K2 for the case halves, after 24h in my (cold) garage it has not become much harder, how lng will it take and how longm miust one wait before starting the engine up?
/Lars S
SLITS
post Apr 4 2012, 09:13 AM
"This Utah shit is HARSH!"
It doesn't cure hard
Temperature stability: -40°C to +200°C.
In engine maintenance many sealed joints are required above
all to be easily separable or disassembled. Curil K2 meets this
requirement: it does not cure. Curil K2’s low viscosity makes it
ideal for sealing finely finished and superfinished components
whose prescribed tolerances are not allowed to be changed.
Joints sealed with Curil K2 remain leak proof under mechanical,
chemical and thermal loads and yet are still easy to separate.
These special advantages mean that Curil K2 can be used for
joints between identical or different metals, threaded seals,
etc. Curil K2 is resistant to mineral oils (also with additives),
greases, hot and cold water, seawater, gases and air.
Application
Clean and degrease the sealing surfaces. Apply Curil K2 and
leave for 5 – 10 minutes before fitting the parts together.
Processing temperature: +5°C to +30°C.
Their other product Curil does cure ...
- Lo-Fi Version Time is now: 5th October 2026 - 08:01 AM
