930 (108mm) output flange identification, Two pair with different seal landing dimensions |
pcar916 |
Apr 9 2012, 04:45 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
Anyone know these two 108mm applications?
Both (on the right) are 108mm course-spline flanges. But as the pic below shows, the center flange has the same dimensions as the 914 flange (left) on all turned surfaces. The 108 flange on the right is the same dimensions (on turned surfaces) as the 100mm SC flanges I use with 944 cv's on my 914. I can just barely make out what I think may be the part number on the rightmost flange. 915.332.209/01 but this may be incorrect. It's not very distinct. Anyone run into both at some point? My guess is that the flange on the right is from the SC era and the center one is an earlier turbo, but I'm basing that on the SC dimension match, not from actual fact. Ideas? |
Eric_Shea |
Apr 9 2012, 06:18 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
They did away with coarse splined flanges after 76 I believe so, the first year Turbo would have been the last. No SC's had them that I am aware of.
Check Sporto vs, Standard... |
Lo-Fi Version | Time is now: 1st June 2024 - 08:03 AM |
