930 (108mm) output flange identification, Two pair with different seal landing dimensions |
pcar916 |
Apr 9 2012, 04:45 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
Anyone know these two 108mm applications?
Both (on the right) are 108mm course-spline flanges. But as the pic below shows, the center flange has the same dimensions as the 914 flange (left) on all turned surfaces. The 108 flange on the right is the same dimensions (on turned surfaces) as the 100mm SC flanges I use with 944 cv's on my 914. I can just barely make out what I think may be the part number on the rightmost flange. 915.332.209/01 but this may be incorrect. It's not very distinct. Anyone run into both at some point? My guess is that the flange on the right is from the SC era and the center one is an earlier turbo, but I'm basing that on the SC dimension match, not from actual fact. Ideas? |
pcar916 |
Apr 9 2012, 07:13 PM
I'll look into that. I didn't think of the sporto because all of it's parts were so small compared to the 901/914 transaxle equivalents, that it was hard to imagine a 108mm cv with one. I'll report back if none of us knows the skinny up front. I've never even seen a 915 based sporto but I may have to cruise through the PET to find the answer.
I have a friend's 914 race box in for a seal installation and his 108's are the same as the pic on the right. |
Lo-Fi Version | Time is now: 6th June 2024 - 05:30 PM |
