> Rusted Longs - Mayeur kit will Fix? - can,t add Pics :-(
gbg10000
post Mar 17 2012, 09:42 AM
Hi All-
I bought a project car site unseen. It was a gamble, and it is worse than I imagined.
Passenger Long is very bad (photo) Door will still open and shut but gap is very narrow. Rear Floor will also need replace.
Question, would the Brad Mayeur kit alone fix this??
I know I probably need pictures of other areas, but if I am not interested in engine bay cosmetics or autocross stiffness, would I need other reinforcing components in the hell hole area or inner long areas for a daily driver scenario?
I have never welded before, and will only be able to have the car on jack stands. I envision buying a cheap 120v flux wire welder and trying it myself. I do not need the covered areas to look pretty underneath, but I do need a good safe structure.
Comments, advice and opinions appreciated.
Thank you.
This post has been edited by gbg10000: Mar 17 2012, 10:13 AM
saigon71
post Apr 12 2012, 07:09 PM
The car is fixable...but you have a ton of work ahead of you. If you commit to doing it, be prepared to go all-in on a restoration because you will find yourself priced in at some point buying stuff, making bailing out tough to justify financially. On the bright side, you will know this car inside & out when you are finished! (IMG:style_emoticons/default/smile.gif)
Like the paintedman said, buy all the replacement panels you can from restoration design...there will be plenty of fabrication to learn from in other areas.
An angle grinder will do a lot of the cutting, but won't allow you to get everywhere you need to. I use a die grinder and a dremmel tool with cutting wheels quite a bit too.
Our projects look quite similar if you want to see what you are in for:
http://www.914world.com/bbs2/index.php?sho...=123957&hl=
Good luck & keep us posted! (IMG:style_emoticons/default/beerchug.gif)
gbg10000   Rusted Longs - Mayeur kit will Fix? - can,t add Pics :-(   Mar 17 2012, 09:42 AM
abnrdo   :ttiwwp:   Mar 17 2012, 09:44 AM
hot_shoe914   Maybe this will answer your question. From Brad hi...   Mar 17 2012, 09:58 AM
shoguneagle   :birthday3: You have just been born into the ...   Mar 17 2012, 12:34 PM
PanelBilly   You have a lot of work ahead to make this car righ...   Mar 17 2012, 01:11 PM
underthetire   That's bad. But what's up with the l80e a...   Mar 17 2012, 01:30 PM
gbg10000   That's bad. But what's up with the l80e ...   Mar 17 2012, 01:37 PM
veltror   That's bad. But what's up with the l80e ...   Mar 17 2012, 05:56 PM
9146986   It looks like the door is closed in the pic, if so...   Mar 18 2012, 01:07 PM
draganc   buy a local 914 guy lunch and ask for his input - ...   Mar 19 2012, 07:17 PM
r_towle   Yes, brads kit will do the structural job, but you...   Mar 19 2012, 07:25 PM
gbg10000   I am going to expose the hell hole, and the floorb...   Mar 20 2012, 08:36 PM
gbg10000   [quote name='gbg10000' post='1650230' date='Mar 20...   Mar 28 2012, 08:18 PM
SirAndy   Please chime in How good are your welding and met...   Mar 28 2012, 09:00 PM
ThePaintedMan   Wow, the long looks almost exactly like what I got...   Mar 28 2012, 09:23 PM
ape914   me and a friend ended up scraping one that had sim...   Mar 28 2012, 10:25 PM
Vacca Rabite   I love seeing a 914 saved, but this is a parts car...   Mar 29 2012, 04:46 AM
gbg10000   Final photos before I decide to try to save this c...   Apr 12 2012, 06:47 PM
saigon71   The car is fixable...but you have a ton of work ah...   Apr 12 2012, 07:09 PM
SCV   Here's one more vote for spending the extra ca...   Apr 12 2012, 08:07 PM
Krieger   Sorry man, that is a parts car. :barf:   Apr 12 2012, 09:59 PM
kg6dxn   There are always nice rollers on SF Bay Craigs Lis...   Apr 12 2012, 10:18 PM
Germancar-Junkie   If you have some $$$$ to play ...   Apr 13 2012, 05:48 AM
reharvey   I've welded up several rusty 914s and I can as...   Apr 13 2012, 07:45 AM
r_towle   That is a typical northeast car IMHO. If you want ...   Apr 13 2012, 08:19 AM
OllieG   I'm about a year into my first 914 resto..I, l...   Apr 13 2012, 09:41 AM
jcambo7   Why discourage some one from trying to fix it. Fo...   Apr 13 2012, 09:48 AM
- Lo-Fi Version Time is now: 3rd July 2025 - 08:48 PM
