Electrical problem, Additional info and questions |
mrholland2 |
Apr 19 2012, 05:15 PM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Okay, I am really irritated with this.
1. I cannot find a short in any wiring 2. The parking lights, which did blow a fuse no longer blow a fuse (more on this later) 3. Now the headlights do with the ignition on 4. The parking light, tail lights, and brake light on the LEFT SIDE ONLY do not work 5. Could the headlight switch be the problem? 6. I have a fuse at the battery. With electronic ignition and carb, how many amps is reasonable for that fuse? Thanks. |
Smitty911 |
Apr 19 2012, 05:19 PM
Member Group: Members Posts: 294 Joined: 19-March 08 From: La Mirada, Ca Member No.: 8,830 Region Association: Southern California |
Okay, I am really irritated with this. 1. I cannot find a short in any wiring 2. The parking lights, which did blow a fuse no longer blow a fuse (more on this later) 3. Now the headlights do with the ignition on 4. The parking light, tail lights, and brake light on the LEFT SIDE ONLY do not work 5. Could the headlight switch be the problem? 6. I have a fuse at the battery. With electronic ignition and carb, how many amps is reasonable for that fuse? Thanks. I'll be of little use here, but here we go. 1. Good 2. Good 3. No shorts, check grounds, that power is being drawn for some reason. 4. Grounds, mine did the same thing until I cleaned them all. 5. Don't know 6. LESS Smitty |
Lo-Fi Version | Time is now: 1st June 2024 - 03:03 PM |
