Electrical problem, Additional info and questions |
mrholland2 |
Apr 19 2012, 05:15 PM
Senior Member Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Okay, I am really irritated with this.
1. I cannot find a short in any wiring 2. The parking lights, which did blow a fuse no longer blow a fuse (more on this later) 3. Now the headlights do with the ignition on 4. The parking light, tail lights, and brake light on the LEFT SIDE ONLY do not work 5. Could the headlight switch be the problem? 6. I have a fuse at the battery. With electronic ignition and carb, how many amps is reasonable for that fuse? Thanks. |
markb |
Apr 19 2012, 05:34 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Lic plate lights, and rear trunk light can both cause issues if not plugged in correctly.
mrholland2 |
Apr 19 2012, 05:41 PM
Lic plate lights, and rear trunk light can both cause issues if not plugged in correctly. Rear LP light didn't work before, I haven't touched it. And there isn't a trunk light. Prior to the fuse snapping (i've used several), and after. . I smell a bit of old hot wiring in the passenger compartment. Right now, I'm only using a 20 Amp fuse for the WHOLE CAR fuse. Thanks guys. . and ladies. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:46 PM |
