Electrical problem, Additional info and questions |
mrholland2 |
Apr 19 2012, 05:15 PM
Senior Member Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Okay, I am really irritated with this.
1. I cannot find a short in any wiring 2. The parking lights, which did blow a fuse no longer blow a fuse (more on this later) 3. Now the headlights do with the ignition on 4. The parking light, tail lights, and brake light on the LEFT SIDE ONLY do not work 5. Could the headlight switch be the problem? 6. I have a fuse at the battery. With electronic ignition and carb, how many amps is reasonable for that fuse? Thanks. |
Tom |
Apr 19 2012, 11:43 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Do you have a pic of your fuse set up? What type of fuse? "All fuses are not created equal". The new ATC fuses are rated at 125% continiously and up to 300% for very short periods, ( 100miliseconds).
If you don't think 20 Amps is too low, just check the values of the fuses in the underdash fuse panel. They add up to over 100 Amps. Of course they are overrated, else they would blow! But they are rated to blow prior to circuit damage, IE: "the wiring" part of the circuit Using only one fuse is asking for problems, IMHO. To get one large enough to provide the current needed, you will be taking a chance of having a single wire short and burning that wire. Tom |
mrholland2 |
Apr 19 2012, 11:45 PM
Do you have a pic of your fuse set up? What type of fuse? "All fuses are not created equal". The new ATC fuses are rated at 125% continiously and up to 300% for very short periods, ( 100miliseconds). If you don't think 20 Amps is too low, just check the values of the fuses in the underdash fuse panel. They add up to over 100 Amps. Of course they are overrated, else they would blow! But they are rated to blow prior to circuit damage, IE: "the wiring" part of the circuit Using only one fuse is asking for problems, IMHO. To get one large enough to provide the current needed, you will be taking a chance of having a single wire short and burning that wire. Tom I have all the old fuses in use under the dash, this is additional. It is the new plastic type fuse. Belt and suspenders both |
Lo-Fi Version | Time is now: 8th June 2024 - 07:03 PM |
