| 914itis |
Apr 21 2012, 05:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
The car runs great as long as I don't hit 3200-3500 rpm. Same spot on all gears and all engine temps.I mentioned 32-3500 since I know that these old gauges are not accurate.
jmill Carbs or FI? Engine size, type and any other pert... Apr 21 2012, 05:55 PM
poorsche914 If FI, could be the TPS (throttle position sensor)... Apr 21 2012, 05:57 PM
914itis Diet 2.0 leaker , if tps I have onee on the way . Apr 21 2012, 06:03 PM
jmill If carbs it could be transition issues or ignition... Apr 21 2012, 06:04 PM
falconfp2001 I'd say the TPS. I had the same symptoms once.... Apr 21 2012, 06:52 PM
vsg914 Yep, the traces are worn. Sometimes you can tweek ... Apr 21 2012, 07:02 PM
914itis
Yep, the traces are worn. Sometimes you can tweek... Apr 21 2012, 07:12 PM
914itis I ordered one from Dave sprinkle last week. I had... Apr 21 2012, 07:09 PM
jim_hoyland Does the L-Jet TPS have the same problem, or is it... Apr 21 2012, 07:13 PM
davesprinkle
Does the L-Jet TPS have the same problem, or is i... Apr 21 2012, 09:41 PM
jim_hoyland
Does the L-Jet TPS have the same problem, or is ... Apr 22 2012, 07:34 PM
euro911 Jim, they're very similar and are prone to the... Apr 21 2012, 07:56 PM
trfrick I had the same problem once and it was the rebuilt... Apr 21 2012, 08:51 PM
euro911 I stand corrected and recant my previous post.
I ... Apr 22 2012, 01:31 AM
bulitt Your car looks great Paul! Apr 22 2012, 05:02 AM
914itis Thanks , I am happy with the outcome . Apr 22 2012, 08:39 AM
underthetire Or the mechanical advance in the dizzy is sticking... Apr 22 2012, 08:14 PM
914itis Update:
I rebilt my original dizzy using the vacu... May 22 2012, 08:39 PM
ConeDodger Pop the cover on the TPS. You will probably find i... May 22 2012, 08:48 PM
914itis
Pop the cover on the TPS. You will probably find ... May 22 2012, 09:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:30 AM |
