> Hesitation / jerking around 3200 to 3500 rpm
914itis
post Apr 21 2012, 05:50 PM
The car runs great as long as I don't hit 3200-3500 rpm. Same spot on all gears and all engine temps.I mentioned 32-3500 since I know that these old gauges are not accurate.
jim_hoyland
post Apr 21 2012, 07:13 PM
Get that VIN ?
Does the L-Jet TPS have the same problem, or is it completely different ?
davesprinkle
post Apr 21 2012, 09:41 PM
QUOTE(jim_hoyland @ Apr 21 2012, 06:13 PM) *
Hi Jim,
I'm going to disagree with the previous poster. The Ljet TPS is substantially different from the Djet TPS. The Djet sensor detects changes in throttle angle of roughly 2º. The Ljet sensor is only used to detect idle and wide-open throttle.
-dave
jim_hoyland
post Apr 22 2012, 07:34 PM
Get that VIN ?
QUOTE(davesprinkle @ Apr 21 2012, 08:41 PM) *
Hi Jim,
-dave
Thanks Dave. Good info
914itis   Hesitation / jerking around 3200 to 3500 rpm   Apr 21 2012, 05:50 PM
jmill   Carbs or FI? Engine size, type and any other pert...   Apr 21 2012, 05:55 PM
poorsche914   If FI, could be the TPS (throttle position sensor)...   Apr 21 2012, 05:57 PM
914itis   Diet 2.0 leaker , if tps I have onee on the way .   Apr 21 2012, 06:03 PM
jmill   If carbs it could be transition issues or ignition...   Apr 21 2012, 06:04 PM
falconfp2001   I'd say the TPS. I had the same symptoms once....   Apr 21 2012, 06:52 PM
vsg914   Yep, the traces are worn. Sometimes you can tweek ...   Apr 21 2012, 07:02 PM
914itis   Yep, the traces are worn. Sometimes you can tweek...   Apr 21 2012, 07:12 PM
914itis   I ordered one from Dave sprinkle last week. I had...   Apr 21 2012, 07:09 PM
jim_hoyland   Does the L-Jet TPS have the same problem, or is it...   Apr 21 2012, 07:13 PM
davesprinkle   Does the L-Jet TPS have the same problem, or is i...   Apr 21 2012, 09:41 PM
jim_hoyland   Does the L-Jet TPS have the same problem, or is ...   Apr 22 2012, 07:34 PM
euro911   Jim, they're very similar and are prone to the...   Apr 21 2012, 07:56 PM
trfrick   I had the same problem once and it was the rebuilt...   Apr 21 2012, 08:51 PM
euro911   I stand corrected and recant my previous post. I ...   Apr 22 2012, 01:31 AM
bulitt   Your car looks great Paul!   Apr 22 2012, 05:02 AM
914itis   Thanks , I am happy with the outcome .   Apr 22 2012, 08:39 AM
underthetire   Or the mechanical advance in the dizzy is sticking...   Apr 22 2012, 08:14 PM
914itis   Update: I rebilt my original dizzy using the vacu...   May 22 2012, 08:39 PM
ConeDodger   Pop the cover on the TPS. You will probably find i...   May 22 2012, 08:48 PM
914itis   Pop the cover on the TPS. You will probably find ...   May 22 2012, 09:49 PM
- Lo-Fi Version Time is now: 9th June 2026 - 02:33 AM
