| 02loftsmoor |
Apr 23 2012, 08:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region
OK Campers who have repaired your relayboards, what did you us to clean the copper to be able to solder the connections WES (IMG:style_emoticons/default/idea.gif)
| Tom |
Apr 24 2012, 06:35 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
I have never done a relay board, however I have repaired many circuit boards in electronic equipment. Use a pencil type eraser to clean the area to be soldered, then flush with isopropyl alcohol. Cleanliness is a must for good soldering.
If after cleaning, the solder does not "flow" well, try some flux. Just be sure to wash again after completed. Tom |
02loftsmoor circuit board Apr 23 2012, 08:23 PM
02loftsmoor wondering would acid flux be a bit aggressive
... Apr 24 2012, 06:56 AM
falconfp2001
... Apr 24 2012, 11:59 PM
budk alcohol and a scuff pad. Apr 24 2012, 06:51 AM
rwilner I think some people have used a dremel with a wire... Apr 24 2012, 06:55 AM
02loftsmoor those copper strips a very thin. be careful. I got... Apr 24 2012, 06:57 AM
walterolin Don't use acid core, the residual flux may con... Apr 24 2012, 07:34 AM
Joe Owensby I used the Dremel tool. I also made a little mor... Apr 24 2012, 08:47 PM
Mr.242 As a kid we put a penny in lemon juice and it made... Apr 24 2012, 09:34 PM
underthetire You got a lot more tar to get off first. I heated ... Apr 24 2012, 09:52 PM
kg6dxn There is really no "electrical" need to ... Apr 24 2012, 10:19 PM
HarveyH I did this last summer. I scraped out the traces w... Apr 25 2012, 06:28 AM
Bartlett 914
I did this last summer. I scraped out the traces ... Apr 25 2012, 06:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th November 2026 - 12:22 AM |
