| 02loftsmoor |
Apr 23 2012, 08:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region
OK Campers who have repaired your relayboards, what did you us to clean the copper to be able to solder the connections WES (IMG:style_emoticons/default/idea.gif)
| Mike Bellis |
Apr 24 2012, 10:19 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
There is really no "electrical" need to clean the copper under the board. DC current travels in the center of the conductor unlike AC which has a skin effect. The copper terminals on the top can be cleaned for better contact.
Get all the loose debris off it. Check for any possible cold solder joints and fill with 3M electrical epoxy. Done. Pollishing the copper or wire wheeling it is a waste of time unles there is physical damage. |
02loftsmoor circuit board Apr 23 2012, 08:23 PM
Tom I have never done a relay board, however I have re... Apr 24 2012, 06:35 AM
02loftsmoor wondering would acid flux be a bit aggressive
... Apr 24 2012, 06:56 AM
falconfp2001
... Apr 24 2012, 11:59 PM
budk alcohol and a scuff pad. Apr 24 2012, 06:51 AM
rwilner I think some people have used a dremel with a wire... Apr 24 2012, 06:55 AM
02loftsmoor those copper strips a very thin. be careful. I got... Apr 24 2012, 06:57 AM
walterolin Don't use acid core, the residual flux may con... Apr 24 2012, 07:34 AM
Joe Owensby I used the Dremel tool. I also made a little mor... Apr 24 2012, 08:47 PM
Mr.242 As a kid we put a penny in lemon juice and it made... Apr 24 2012, 09:34 PM
underthetire You got a lot more tar to get off first. I heated ... Apr 24 2012, 09:52 PM
HarveyH I did this last summer. I scraped out the traces w... Apr 25 2012, 06:28 AM
Bartlett 914
I did this last summer. I scraped out the traces ... Apr 25 2012, 06:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th November 2026 - 12:22 AM |
