> circuit board, cleaning the copper
02loftsmoor
post Apr 23 2012, 08:23 PM
OK Campers who have repaired your relayboards, what did you us to clean the copper to be able to solder the connections WES (IMG:style_emoticons/default/idea.gif) Attached ImageAttached Image
HarveyH
post Apr 25 2012, 06:28 AM
I did this last summer. I scraped out the traces with a small screwdriver and dental picks. I then used a Dremel tool with a small round bristle brush and kitchen cleanser. Washed well with soap and water and flushed with Isopropyl Alcohol. Soldered with rosin core electronic solder (the old Tin-Lead type). On some terminals I used a bit of additional rosin flux. Cleaned with Isopropyl again. Coated the back of the board using Plasti-Coat or whatever it is that you use to dip tool handles in. I used an acid brush and multiple coats, alowing to dry overnight between coats.
Harvey
- Lo-Fi Version Time is now: 8th November 2026 - 12:22 AM
