Locking steering column...???, is this a necessity??? |
Mueller |
May 25 2004, 10:59 AM
currently locking mechanism broken*, if one never planned to park on a hill, should one bother fixing it?
as an anti-theft device, the steering wheel can be unlocked if enough force is used (I've done it by cranking on the wheel without too much effort) *can turn wheel with key out of ignition |
Mueller |
May 25 2004, 11:43 AM
Hey Dave....
nope the 1.8 is not running yet, it is installed into the car....I broke an exhaust stud on the original 1.8 heads, so I installed re-built 2.0 heads on the 1.8 motor....then I had two exhaust studs pull out of the head while I was installing the stub pipes of the header..... today I will heli-coil and re-install some brand new studs in that one particular head. The other two studs came fairly easy..... |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:45 AM |
