Need your thoughts - rear bar |
Cracker |
May 1 2012, 07:03 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Rear Sway Bar
Need the pros & cons, options and what YOU have actually used. Basically, I have found that there is only the small factory assembly and the Weltmiester system available. I spoke with Ira at Tarret Eng. yesterday but the few prototypes he built years ago are all gone. Goal I'm running 315/35/17 rears, a LSD and 300 lbs rear springs. I still have way too much rear body roll than I want. I've tightened up the front sway bar and removed rear camber and that has helped but feel I need a rear bar help beyond that with the body roll out back. Your thoughts & options? |
stewteral |
May 15 2012, 08:58 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Rear Sway Bar Need the pros & cons, options and what YOU have actually used. Basically, I have found that there is only the small factory assembly and the Weltmiester system available. I spoke with Ira at Tarret Eng. yesterday but the few prototypes he built years ago are all gone. Goal I'm running 315/35/17 rears, a LSD and 300 lbs rear springs. I still have way too much rear body roll than I want. I've tightened up the front sway bar and removed rear camber and that has helped but feel I need a rear bar help beyond that with the body roll out back. Your thoughts & options? Hey Cracker: UPDATE INFO: On 05 May, I ran a track day at Willow Springs (the Big track) and found I kept adjusting the rear swaybar SOFTER & SOFTER until it was the Best at only 28 lb/in Wheel Rate. This is a BIG reduction from the previous 96 lbs/in. Last Thursday & Friday I was at Infineon Raceway and found that the Willow setup with 1 step SOFTER front bar gave me my best results ever. The lesson here is to get most of your wheel-rate from the rear springs and just use a SMALL amount of rear bar for fine tuning. With all the weight in the center of the car (Low Polar Moment of Enertia) the car needs only a small amount of Roll-Stiftness to work. As I learned, a big rear bar means nothing but rear instability!! With the softer rear bar, I picked up more understeer, but softening the front bar made it BETTER! Roll is NOT a bad thing as the goal is BALANCE! I'm running a Chevy V8 so my rear springs are at 400#, if you have a 911 motor, of course your springs will be softer. Regardless, dialing in mostly with spring rate and then fine tuning with a "light" rear swaybar is the path to success. Best of luck Terry |
Lo-Fi Version | Time is now: 7th June 2024 - 03:39 PM |
