| rwilner |
May 18 2012, 05:18 AM
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
So with some less-than-gentle persuasion with a rubber mallet, I got the heads off my 1.7 core.
This engine didn't turn over and it's obvious why...the cylinders have rust on the inside and the pistons will not budge. I need to get the Ps and Cs off and I don't care if I damage them as they're toast anyway, but I need to keep the case pristine as this is what I'll be using for my rebuild (really it's why I bought the core). So, any tricks to free up and remove the pistons and cylinders? More persuasion with a rubber mallet? Gallons of PB blaster? Mild explosive? |
| Rex-n-effect |
May 18 2012, 07:56 AM
Newbie ![]() Group: Members Posts: 44 Joined: 4-February 11 From: Missoula, MT Member No.: 12,659 Region Association: None |
Mine had the same issue when i got it. They had been soaked in water for about 12 years so you can imagine what kind of bonding had been going on. They were so bad that, well lets just leave it at that. I soaked in rust penetrant for weeks before i tackled this. When this had no effect i ended up using the BFH (metal) to knock them off. I had pieces of cylinder fins all over the shop but i got them off. When i got too close to the case i used wood blocks and brass drifts to wack the crap out of it. Took a long time but they eventually came off. Good luck!!!!
rwilner How do I remove stubborn pistons / cylinders? May 18 2012, 05:18 AM
ArtechnikA Penetrants, heat, patience.
If CHT is in the 350ยบ... May 18 2012, 05:59 AM
hot_shoe914 Rubber mallet. :smash: May 18 2012, 06:32 AM
RobW Wire brush and pick at the base too. Penetrating o... May 18 2012, 07:46 AM
RobW
Mine had the same issue when i got it. They had b... May 18 2012, 08:10 AM
rwilner holy crap.
Looks like I have my work cut out for ... May 18 2012, 08:37 AM
Cupomeat It usually isn't that bad, but be careful with... May 18 2012, 08:54 AM
injunmort turn one side up, fill cylinder with atf and aceto... May 18 2012, 08:57 AM
rwilner
turn one side up, fill cylinder with atf and acet... May 18 2012, 10:32 AM
injunmort i dont think i said bang on it with the hammer, i ... May 18 2012, 01:11 PM
rwilner
i dont think i said bang on it with the hammer, i... May 18 2012, 01:21 PM
Qarl Great video here...
http://www.ephotomotion.com/9... May 18 2012, 01:25 PM
r_towle Bring it over here on Saturday.
We have the tools ... May 18 2012, 09:26 PM
rwilner
We have the tools... May 19 2012, 07:35 AM
tomeric914 Sledgehammer and a 2x4. Look at my build thread t... May 19 2012, 09:51 PM
Cupomeat Confucious says, Yes, even the worst looking situa... May 19 2012, 10:28 PM
euro911 Just be really careful when heating up any chemica... May 20 2012, 01:20 AM
rwilner Ok well, I did a lot of beating with a hammer, hea... May 20 2012, 07:15 PM
moparrob Just curious- would a cutting torch work? May 21 2012, 09:24 AM
ArtechnikA
Hmmm -... May 21 2012, 09:31 AM
rwilner
I think I'd sooner try to split the cylinders... May 21 2012, 10:03 AM
ArtechnikA
I think I'd sooner try to split the cylinder... May 21 2012, 10:30 AM
Rex-n-effect I feel your pain! Cupomeat's picture looks... May 21 2012, 10:15 AM
LotusJoe
So with some less-than-gentle persuasion with a r... May 21 2012, 10:54 AM
jcambo7
So with some less-than-gentle persuasion with a ... May 21 2012, 11:18 AM
ArtechnikA
It's amazing we even drink that stuff too... ... May 21 2012, 11:26 AM
r_towle You are already trashing the pistons, get a hole s... May 21 2012, 08:05 PM
rwilner the coke trick worked! :trophy:
Well, coke, p... May 23 2012, 06:26 PM
euro911 Congrats.
I guess the old saying, "things go... May 23 2012, 07:08 PM
rwilner If this failed, my next step was to ask my phd che... May 24 2012, 06:05 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:45 AM |
