Autocross Setup |
Autocross Setup |
EdwardBlume |
May 15 2012, 11:57 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I'm wanting some input on autcross setup.
1750 lbs 200+ hp /6 Fg flares Front welt bar Torsion unknown Koni adjustable x 4 LSD What spring rates? Camber f and r Toe out? |
Borderline |
May 16 2012, 04:37 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
Rob, I thought you were going to sell the car??? I think Grant had the car set up fairly well. I think your old used tires were worse than my newer used tires. You would have been a lot faster on new or at least newer tires. Tires are everything!! If you decide to buy radial tires, you're going to have to put in a lot more camber on both ends.
Hope you keep the car! (IMG:style_emoticons/default/biggrin.gif) |
EdwardBlume |
May 16 2012, 08:04 PM
Rob, I thought you were going to sell the car??? I think Grant had the car set up fairly well. I think your old used tires were worse than my newer used tires. You would have been a lot faster on new or at least newer tires. Tires are everything!! If you decide to buy radial tires, you're going to have to put in a lot more camber on both ends. Hope you keep the car! (IMG:style_emoticons/default/biggrin.gif) Tires were 4 years old but still working. I'm in for now. I turned down a serious offer of $12,000 because I had too much fun. I'll run it until I don't use it again, and then I'll let it go... maybe fix it up some more... (IMG:style_emoticons/default/idea.gif) |
DanT |
May 17 2012, 12:27 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Rob, I thought you were going to sell the car??? I think Grant had the car set up fairly well. I think your old used tires were worse than my newer used tires. You would have been a lot faster on new or at least newer tires. Tires are everything!! If you decide to buy radial tires, you're going to have to put in a lot more camber on both ends. Hope you keep the car! (IMG:style_emoticons/default/biggrin.gif) Tires were 4 years old but still working. I'm in for now. I turned down a serious offer of $12,000 because I had too much fun. I'll run it until I don't use it again, and then I'll let it go... maybe fix it up some more... (IMG:style_emoticons/default/idea.gif) Rob, the last time I drove the car the only thing I felt it needed was to freshen the LSD. At the Shootout it was allowing the inside tire to spin off of tighter corners. It needs new tires and possible an alignment for AX. For the Shootout it had track alignment and new tires...that was it. We did pretty well with it that way. That is a top 5 GGR AX car all day! Run Hoosiers and get an alignment, make sure the LSD is functioning properly and that car will fly! (IMG:style_emoticons/default/smile.gif) Check with Grant, I am sure he can tell you everything that is there so you can adjust to your preferences |
EdwardBlume |
May 18 2012, 08:08 AM
Rob, I thought you were going to sell the car??? I think Grant had the car set up fairly well. I think your old used tires were worse than my newer used tires. You would have been a lot faster on new or at least newer tires. Tires are everything!! If you decide to buy radial tires, you're going to have to put in a lot more camber on both ends. Hope you keep the car! (IMG:style_emoticons/default/biggrin.gif) Tires were 4 years old but still working. I'm in for now. I turned down a serious offer of $12,000 because I had too much fun. I'll run it until I don't use it again, and then I'll let it go... maybe fix it up some more... (IMG:style_emoticons/default/idea.gif) Rob, the last time I drove the car the only thing I felt it needed was to freshen the LSD. At the Shootout it was allowing the inside tire to spin off of tighter corners. It needs new tires and possible an alignment for AX. For the Shootout it had track alignment and new tires...that was it. We did pretty well with it that way. That is a top 5 GGR AX car all day! Run Hoosiers and get an alignment, make sure the LSD is functioning properly and that car will fly! (IMG:style_emoticons/default/smile.gif) Check with Grant, I am sure he can tell you everything that is there so you can adjust to your preferences It was fuel. Even with a quarter tank, I was getting fuel starvation. 3/4 to Full - no problem. No slip. I'm a little lost on the suspension because I did well with the 2.0 and a balanced car, while this is rear weighted and a ton more power... I kept expecting to lean hard on a rail that wasn't there.... new tires would be good. |
Lo-Fi Version | Time is now: 3rd June 2024 - 09:17 AM |
