> Timing confusion
914itis
post May 18 2012, 06:34 AM
Ok, either I am dumb, confused or a combination of both.
I am having some other issued with my car and decided to recomfirm timing once again. I went back to the pelican web site to make sure i got it right, then run into this. I was able to fing my timing mark on the impeller. I first followed the main instructions with thr first picture, showing how to to mark the 27 btdc
Then at the end there is a post by the much respectable Dave, showing an impeller with both the tdc and 27drgree btdc. (see pic #2)
the blue arrow shows factory tdc, red shows factory 27btdc, according to the instructions and template, should'nt 27btdc on the brown arrow?
LotusJoe
post May 18 2012, 08:12 AM
Europa Twink Driver
QUOTE(914itis @ May 18 2012, 05:34 AM) *
I think the confusion maybe, that in the top picture the fan is turned around. The front of the engine is at the bottom of the picture. In other words if you turned the picture 180 degrees the advance marks would be on the proper side of the factory TDC mark.
914itis
post May 18 2012, 08:20 AM
QUOTE(LotusJoe @ May 18 2012, 10:12 AM) *
They are at the same position, on the top picture, the top dead center mark looks like a notch as on the impeller it is a mark. the notch on the impeller is actually the 27btdc.
I hope I got it right this time. (IMG:style_emoticons/default/poke.gif)
914itis   Timing confusion   May 18 2012, 06:34 AM
vsg914   You have it backwards Paul, the red arrow is tdc. ...   May 18 2012, 06:55 AM
914itis   You have it backwards Paul, the red arrow is tdc....   May 18 2012, 07:05 AM
vsg914   Do you remember our conversation about the first b...   May 18 2012, 07:17 AM
914itis   yes I did, and your explanation was great, I was j...   May 18 2012, 07:25 AM
LotusJoe   Ok, either I am dumb, confused or a combination o...   May 18 2012, 08:12 AM
914itis   Ok, either I am dumb, confused or a combination ...   May 18 2012, 08:20 AM
vsg914   Lotus Joe is correct, but thats not the problem. T...   May 18 2012, 08:58 AM
914itis   Lotus Joe is correct, but thats not the problem. ...   May 18 2012, 09:27 AM
Dave_Darling   On my picture, the red-painted mark is a notch. I...   May 18 2012, 09:17 AM
914itis   On my picture, the red-painted mark is a notch. ...   May 18 2012, 09:31 AM
vsg914   1.8 fans had the timing mark at 7.5 degrees. The t...   May 18 2012, 09:32 AM
914itis   1.8 fans had the timing mark at 7.5 degrees. The ...   May 18 2012, 09:43 AM
Dave_Darling   Double-check the fan against the flywheel mark. I...   May 18 2012, 11:49 AM
914itis   Double-check the fan against the flywheel mark. ...   May 18 2012, 12:31 PM
vsg914   Your a brave man Dave. LOL   May 18 2012, 12:26 PM
vsg914   Yes, but it comes up twice in the cycle. The flywh...   May 18 2012, 12:52 PM
914itis   Yes, but it comes up twice in the cycle. The flyw...   May 18 2012, 12:57 PM
Dave_Darling   Oh, then you should be able to use a chopstick...   May 18 2012, 05:18 PM
- Lo-Fi Version Time is now: 12th July 2025 - 11:46 PM
