| rwilner |
May 18 2012, 05:18 AM
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
So with some less-than-gentle persuasion with a rubber mallet, I got the heads off my 1.7 core.
This engine didn't turn over and it's obvious why...the cylinders have rust on the inside and the pistons will not budge. I need to get the Ps and Cs off and I don't care if I damage them as they're toast anyway, but I need to keep the case pristine as this is what I'll be using for my rebuild (really it's why I bought the core). So, any tricks to free up and remove the pistons and cylinders? More persuasion with a rubber mallet? Gallons of PB blaster? Mild explosive? |
| injunmort |
May 18 2012, 08:57 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
turn one side up, fill cylinder with atf and acetone, heat the cylinder with a torch. tap piston with rubber mallet and they should free up. if the piston is down in the bore, use a piece of wood as a drift to get it free. repeat on other side. good luck, with some paitience and heat they should all come free without much drama.
| rwilner |
May 18 2012, 10:32 AM
turn one side up, fill cylinder with atf and acetone, heat the cylinder with a torch. tap piston with rubber mallet and they should free up. if the piston is down in the bore, use a piece of wood as a drift to get it free. repeat on other side. good luck, with some paitience and heat they should all come free without much drama. By doing all the banging with a hammer, is there any risk of transferring the loads to the engine case internals and damaging it...for example, damaging the crank bores? I am planning an align bore anyway... |
rwilner How do I remove stubborn pistons / cylinders? May 18 2012, 05:18 AM
ArtechnikA Penetrants, heat, patience.
If CHT is in the 350ยบ... May 18 2012, 05:59 AM
hot_shoe914 Rubber mallet. :smash: May 18 2012, 06:32 AM
RobW Wire brush and pick at the base too. Penetrating o... May 18 2012, 07:46 AM
Rex-n-effect Mine had the same issue when i got it. They had be... May 18 2012, 07:56 AM
RobW
Mine had the same issue when i got it. They had b... May 18 2012, 08:10 AM
rwilner holy crap.
Looks like I have my work cut out for ... May 18 2012, 08:37 AM
Cupomeat It usually isn't that bad, but be careful with... May 18 2012, 08:54 AM
injunmort i dont think i said bang on it with the hammer, i ... May 18 2012, 01:11 PM
rwilner
i dont think i said bang on it with the hammer, i... May 18 2012, 01:21 PM
Qarl Great video here...
http://www.ephotomotion.com/9... May 18 2012, 01:25 PM
r_towle Bring it over here on Saturday.
We have the tools ... May 18 2012, 09:26 PM
rwilner
We have the tools... May 19 2012, 07:35 AM
tomeric914 Sledgehammer and a 2x4. Look at my build thread t... May 19 2012, 09:51 PM
Cupomeat Confucious says, Yes, even the worst looking situa... May 19 2012, 10:28 PM
euro911 Just be really careful when heating up any chemica... May 20 2012, 01:20 AM
rwilner Ok well, I did a lot of beating with a hammer, hea... May 20 2012, 07:15 PM
moparrob Just curious- would a cutting torch work? May 21 2012, 09:24 AM
ArtechnikA
Hmmm -... May 21 2012, 09:31 AM
rwilner
I think I'd sooner try to split the cylinders... May 21 2012, 10:03 AM
ArtechnikA
I think I'd sooner try to split the cylinder... May 21 2012, 10:30 AM
Rex-n-effect I feel your pain! Cupomeat's picture looks... May 21 2012, 10:15 AM
LotusJoe
So with some less-than-gentle persuasion with a r... May 21 2012, 10:54 AM
jcambo7
So with some less-than-gentle persuasion with a ... May 21 2012, 11:18 AM
ArtechnikA
It's amazing we even drink that stuff too... ... May 21 2012, 11:26 AM
r_towle You are already trashing the pistons, get a hole s... May 21 2012, 08:05 PM
rwilner the coke trick worked! :trophy:
Well, coke, p... May 23 2012, 06:26 PM
euro911 Congrats.
I guess the old saying, "things go... May 23 2012, 07:08 PM
rwilner If this failed, my next step was to ask my phd che... May 24 2012, 06:05 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:30 AM |
