> Timing confusion
914itis
post May 18 2012, 06:34 AM
Ok, either I am dumb, confused or a combination of both.
I am having some other issued with my car and decided to recomfirm timing once again. I went back to the pelican web site to make sure i got it right, then run into this. I was able to fing my timing mark on the impeller. I first followed the main instructions with thr first picture, showing how to to mark the 27 btdc
Then at the end there is a post by the much respectable Dave, showing an impeller with both the tdc and 27drgree btdc. (see pic #2)
the blue arrow shows factory tdc, red shows factory 27btdc, according to the instructions and template, should'nt 27btdc on the brown arrow?
TheCabinetmaker
post May 18 2012, 12:52 PM
I drive my car everyday
Yes, but it comes up twice in the cycle. The flywheel notch is visible from the top when cylinder 1 is at tdc and again when 3 is at tdc. You need to make sure you have it on #1
914itis
post May 18 2012, 12:57 PM
QUOTE(vsg914 @ May 18 2012, 02:52 PM) *
Got it
914itis   Timing confusion   May 18 2012, 06:34 AM
vsg914   You have it backwards Paul, the red arrow is tdc. ...   May 18 2012, 06:55 AM
914itis   You have it backwards Paul, the red arrow is tdc....   May 18 2012, 07:05 AM
vsg914   Do you remember our conversation about the first b...   May 18 2012, 07:17 AM
914itis   yes I did, and your explanation was great, I was j...   May 18 2012, 07:25 AM
LotusJoe   Ok, either I am dumb, confused or a combination o...   May 18 2012, 08:12 AM
914itis   Ok, either I am dumb, confused or a combination ...   May 18 2012, 08:20 AM
vsg914   Lotus Joe is correct, but thats not the problem. T...   May 18 2012, 08:58 AM
914itis   Lotus Joe is correct, but thats not the problem. ...   May 18 2012, 09:27 AM
Dave_Darling   On my picture, the red-painted mark is a notch. I...   May 18 2012, 09:17 AM
914itis   On my picture, the red-painted mark is a notch. ...   May 18 2012, 09:31 AM
vsg914   1.8 fans had the timing mark at 7.5 degrees. The t...   May 18 2012, 09:32 AM
914itis   1.8 fans had the timing mark at 7.5 degrees. The ...   May 18 2012, 09:43 AM
Dave_Darling   Double-check the fan against the flywheel mark. I...   May 18 2012, 11:49 AM
914itis   Double-check the fan against the flywheel mark. ...   May 18 2012, 12:31 PM
vsg914   Your a brave man Dave. LOL   May 18 2012, 12:26 PM
vsg914   Yes, but it comes up twice in the cycle. The flywh...   May 18 2012, 12:52 PM
914itis   Yes, but it comes up twice in the cycle. The flyw...   May 18 2012, 12:57 PM
Dave_Darling   Oh, then you should be able to use a chopstick...   May 18 2012, 05:18 PM
- Lo-Fi Version Time is now: 12th July 2025 - 10:48 PM
