> 914-6 transmission rebuild, Can I reuse the 1st gear
914Gelb
post Feb 8 2012, 03:06 AM
Region Association: Austria
Hello guys,
I've bought my car without any test drive because it was unsed many years. Now my transmission is on my todo list. I already opened the case to inspect the 1st gear. I saw a syncro ring which seems to be less used but the dog teeth and the slider speeks other words. My impression.. I have to change slider, dog teeth and syncro. I added some pictures, who can distinguish between poo parts and reusable ones.
Dr Evil
post May 23 2012, 02:08 PM
Send me your transmission!
Did you need the smaller bearing that goes above the larger one in the case as well?
914Gelb   914-6 transmission rebuild   Feb 8 2012, 03:06 AM
Dr Evil   Your slider looks fantastic. The gears show typica...   Feb 8 2012, 08:55 AM
Dr Evil   Oh, while you are in there, you should change out ...   Feb 8 2012, 08:56 AM
914Gelb   Oh, while you are in there, you should change out...   Feb 9 2012, 01:50 AM
jimkelly   no pic of a worn out slider but its the teeth, jus...   Feb 9 2012, 04:01 AM
914Gelb   I now know how new teeth should look like, but is ...   Feb 9 2012, 04:57 AM
Dr Evil   You can reuse teeth from other gears as long as yo...   Feb 9 2012, 12:39 PM
Dr Evil   As for wear limit, I do not know of an indicator. ...   Feb 9 2012, 12:41 PM
914Gelb   Hello I continued my transmission rebuild and ha...   May 14 2012, 11:49 PM
Dr Evil   That is toast. The race in the case should not mov...   May 15 2012, 06:50 AM
914Gelb   So, it'S not possible to get ring and pinion i...   May 15 2012, 07:04 AM
Richard Casto   Georg, Regarding the bore for the roller bearing,...   May 15 2012, 02:17 PM
Dr Evil   I agree that another core would be a better invest...   May 15 2012, 02:55 PM
914Gelb   Thanks for the answers! I also think it makes...   May 15 2012, 11:35 PM
Dr Evil   There is another alternative to changing cases. Th...   May 16 2012, 06:38 AM
914Gelb   I will measure the outer race of the bearing, do I...   May 20 2012, 01:24 PM
Dr Evil   Yes, the bearing should be replaced as a unit to b...   May 20 2012, 02:46 PM
914Gelb   Hello, I measured the ring 72.00mm!   May 23 2012, 01:03 PM
914Gelb   Next step of transmission rebuild, 1st gear dogtee...   May 23 2012, 01:21 PM
914Gelb   Next step installation of new dogteeht.   May 23 2012, 01:35 PM
914Gelb   Last step the check according the manual. Perfect....   May 23 2012, 01:45 PM
Dr Evil   Hey Georg, Great work. I have had only one ring b...   May 23 2012, 02:07 PM
Dr Evil   Did you need the smaller bearing that goes above t...   May 23 2012, 02:08 PM
Richard Casto   Georg, As Mike mentioned above, sometimes the rin...   May 23 2012, 02:56 PM
914Gelb   I continued my work with cleaning some parts of th...   May 27 2012, 01:50 PM
Dr Evil   I will go out and measure the bearing right now. I...   May 27 2012, 02:31 PM
914Gelb   That's fine, If I have all parts I will finish...   May 27 2012, 02:37 PM
914Gelb   I have to leave for today, I will anwser your mail...   May 27 2012, 02:41 PM
914Gelb   more pictures from my transmission rebuild. I made...   Sep 10 2012, 12:15 PM
914Gelb   2nd option of S&P setting. Pls. tell me y...   Sep 10 2012, 12:23 PM
914Gelb   I bought the tool (VW 385)to measure the pinion de...   Oct 11 2012, 12:53 AM
Cairo94507   That is a beautiful transaxle you have there. Con...   Oct 11 2012, 06:51 AM
rjames   wow. Nicely done!   Oct 11 2012, 10:43 AM
Dr Evil   Good job, Georg :thumbsup: What was the price for ...   Oct 11 2012, 11:25 AM
914Gelb   Hello, the price was match more than 400. The too...   Oct 11 2012, 11:13 PM
Cairo94507   ....oh no....he wants to see the Doc's tool......   Oct 12 2012, 06:43 AM
Dr Evil   My tool is made out of an old differential and was...   Oct 12 2012, 03:12 PM
- Lo-Fi Version Time is now: 25th November 2026 - 10:38 AM
