smj's 914-6 clean-up thread, I never created one of these? Huh. |
smj |
May 24 2012, 04:08 AM
"Dude, Steve from Berkeley." Group: Members Posts: 591 Joined: 28-August 05 From: Berkeley, CA Member No.: 4,691 Region Association: Northern California |
Apparently I was waiting for something before I started a thread for work on my 914-6. Whatever - the car stopped turning over while I was between mechanics and wound up sitting with a dead PermaTune box for a couple years. Better late than never, I'll start the thread now...
It's a factory 914-6 that was modified and repainted before I got it. Steel slant-nose, Brembo GT brakes up front, old fronts moved to the rear (and original rears long gone), 3.0 liter SC motor with Webers, 6 & 7 x 16 Fuchs from an '86 Carrera, etc. Started out in Signal Orange, but it's been through at least two color changes since then (white, then black). And as of late May 2012, the odometer has just clicked over 00,000 miles (believed to be the first time based on included paperwork). VIN # 914 043 2486 Orig Engine # 64? ???? (need to order COA) Trans # 750 2505 Karmann body # 132566 (stamped inboard of lock, floor of rear trunk) Here's the standard shot of the car from pictures taken after I took delivery. Edit 8/2014: Added various ID numbers |
smj |
May 24 2012, 04:31 AM
I changed the oil because it had sat for a couple years, even though I'd only put ~360 miles on the car. Then Tom wanted me to put a few hundred miles on the car before trying to decide if I really needed a rebuild or not. Maybe it would be smoking from oil getting by the rings, and maybe it wouldn't with some use...
Problem was, whenever I would run the car I would get a fair bit of fluid flying out of the oil tank breather - a mix of oil and condensate getting on the engine/tin and dripping down onto the hot exhaust, causing a lot of smoke. Here's what the original positioning of the breather was like - a K&N filter rigged to some hose and pipe, hanging out almost over the valve cover. In this photo you can see that there's already some dripping from the base of the filter onto the engine bay wall below. Attached image(s) |
Lo-Fi Version | Time is now: 28th May 2024 - 07:09 PM |
