Need your thoughts - rear bar |
Cracker |
May 1 2012, 07:03 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Rear Sway Bar
Need the pros & cons, options and what YOU have actually used. Basically, I have found that there is only the small factory assembly and the Weltmiester system available. I spoke with Ira at Tarret Eng. yesterday but the few prototypes he built years ago are all gone. Goal I'm running 315/35/17 rears, a LSD and 300 lbs rear springs. I still have way too much rear body roll than I want. I've tightened up the front sway bar and removed rear camber and that has helped but feel I need a rear bar help beyond that with the body roll out back. Your thoughts & options? |
DanT |
May 1 2012, 08:47 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Have never run a rear bar on any of my personal 914s, but have driven several with rear bar...
Properly setup, I have never felt the need for a rear bar. |
Randal |
May 25 2012, 10:46 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
SirAndy |
May 25 2012, 02:55 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Have never run a rear bar on any of my personal 914s, but have driven several with rear bar... Properly setup, I have never felt the need for a rear bar. +1 -1 (IMG:style_emoticons/default/biggrin.gif) WARNING: Personal opinion alert! I added a rear (stock) bar and it made quite a difference. Not so much in handling, as you can dial in pretty much any type of handling to your personal preference anyways. What it did do however is that it really helps keeping the rear of the car level and planted during hard cornering. Many track cars get the same effect by going with very heavy springs and stiff shocks in the rear. But in my personal opinion, it is beneficial to use a rear bar and be able to run a softer setup on the springs and shocks. This has allowed me to step down on my rear spring rates from 250lbs to 200lbs yet the car is flatter through the turns and the rear seems to have more "bite" than before. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 03:08 AM |
