Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
OK, all you big time racers out there, what is the correct procedure to purge air out of a tire before filling it with nitrogen?
The reason I ask is that any moisture mixed with nitrogen will create nitric acid, or some such vile stuff, if I remember correctly. What about using air tools? Looks like a job for rubber gloves. |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
the nitrogen benefit (IIRC) is that it won't gain as much pressure as regular ole atmosphere air, so therefore, tire pressures can be maintainted easier.
Lo-Fi Version | Time is now: 15th July 2025 - 05:12 AM |
