I finally split my 1.7 case, pics added |
rwilner |
May 29 2012, 08:49 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I was told this engine came from a 1.7 that was in a 914. I'm tearing it down to rebuild into a 2056.
First, I found an M12 or M14 triple square bolt with a spring under it. This bolt is located between two pushrod tubes. I'm guessing this is the oil pressure relief since I didn't find the giant slotted plug I was expecting to find...true? Second, there is no windage tray. Did the early motors not have a windage tray? Should I source one and install it? I don't see anyplace in the casting that would receive the tray... Third, I didn't find the serial number where I expected it to be -- in front of the breather tower. Where else could it be? It seems like a low mile case to me...lifters and cam bearings show minimal wear, the cam looks to even be reusable to my untrained eye. If I had to guess i'd say this was a low-mile motor that got parked due to FI problems or something. have no pics but will post some tonight. |
Cap'n Krusty |
May 29 2012, 12:05 PM
Serial numbers: Early bus cases didn't have a number. It was located on the fan housing. An early bus case can be identified by the oil filler passage next to the taco plate opening, the fuel pump flange being finished for use, and the lack of a dipstick tube on the top of the case.
If you add a windage tray, you'll need the tray, the four seals, and an oil pickup modified to allow attachment of the tray. The Cap'n |
rwilner |
May 29 2012, 12:14 PM
Serial numbers: Early bus cases didn't have a number. It was located on the fan housing. An early bus case can be identified by the oil filler passage next to the taco plate opening, the fuel pump flange being finished for use, and the lack of a dipstick tube on the top of the case. based on this I do indeed have a 914 case, as the dipstick is on top of the case. QUOTE If you add a windage tray, you'll need the tray, the four seals, and an oil pickup modified to allow attachment of the tray. The Cap'n Is there anything special about the cases that came from the factory with the tray installed? In other words -- does the tray slip into some grooves that were cast into the later cases (which may be absent in my early 1.7 case)? |
Lo-Fi Version | Time is now: 1st June 2024 - 07:46 PM |
