> Backfiring problem
r_towle
post May 28 2004, 07:30 PM
Custom Member
Hi,
72 1.7 liter
DJet
Timing set, dwell set, new plug, points and condensor.
Valves just re-adjusted and checked again.
It backfires through the throttle body...
Low power, then surges as if it cleared its throught
the backfiring again.....
HELP
Suggestions needed
Rich
TheCabinetmaker
post May 28 2004, 07:34 PM
I drive my car everyday
Did you set the timing before setting the dwell?
r_towle   Backfiring problem   May 28 2004, 07:30 PM
vsg914   Did you set the timing before setting the dwell?   May 28 2004, 07:34 PM
r_towle   valves, dwell, timing in that order, always Rich   May 28 2004, 07:39 PM
vsg914   OK, just checking. Ya never know! Did this jus...   May 28 2004, 07:47 PM
r_towle   did it last year, tuned it up and it went away.......   May 28 2004, 07:49 PM
vsg914   Well, sometimes it just don't make any sense, ...   May 28 2004, 08:02 PM
mike_the_man   Could be the trigger points. There's no good ...   May 31 2004, 04:33 PM
Bullet   I always though that a backfire was cuased by the ...   May 31 2004, 06:12 PM
efrenv   Had the same symptoms with my car. Adjusted valves...   May 31 2004, 11:25 PM
Toast
- Lo-Fi Version Time is now: 3rd March 2026 - 07:06 AM
