| KaptKaos |
Jun 9 2012, 09:22 AM
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
UPDATE: Self inflicted wounds are the worst. She's running.
So the other day when I was charging the battery, I knocked loose one of the 4 leads off of the positive terminal of the battery. I didn't know I had done it. I am not sure what made me go check the battery, but as soon as I did, the wire dropped out. Tom - I think that this is what your fuse box is for? Figures. Thanks for all of your help. Swapped in known good relay from headlight motor for fuel pump. No dice. No power to the fuel pump. Fuses all look good. Going to replace the fuel pump one anyway. Trans ground looks ok, but think I will double-check that. Is there anything else I should be looking for? Not sure if this is related, but a few weeks ago, my dash lights stopped lighting. The blinkers and idiot lights work, just not the illumination when the headlights are on. I actually have some time this morning, and am going to try to diagnose my fuel pump issues. Got a multi-meter, got some help to turn the key, and got a local VW store I can get a new pump or relay from. So, which relay on the panel in the engine bay is for the fuel pump? I have a SirAndy Jumper in there (see his classic article). Also, my multi-meter has ranges. Which setting should I use to test for power to the fuel pump? Thanks in advance. |
kg6dxn :D
Jun 9 2012, 09:47 AM
KaptKaos Thanks Mike! Jun 9 2012, 09:55 AM
walterolin KG6DXN beat me to it. The Haynes manual shows the... Jun 9 2012, 09:58 AM
KaptKaos Update in first post. Jun 9 2012, 12:18 PM
Travis Neff Try Brad anders DJET page, he has a fuel pump diag... Jun 9 2012, 12:28 PM
KaptKaos
Try Brad anders DJET page, he has a fuel pump dia... Jun 9 2012, 12:35 PM
markb You started from the beginning, and spun all the f... Jun 9 2012, 12:28 PM
KaptKaos
You started from the beginning, and spun all the ... Jun 9 2012, 12:37 PM
markb Do a quick search here for ground points. I'm ... Jun 9 2012, 12:40 PM
Travis Neff http://members.rennlist.com/pbanders/FPChecklist_f... Jun 9 2012, 01:03 PM
Tom With your multimeter on 50 volt scale, check pin 3... Jun 9 2012, 01:04 PM
KaptKaos
With your multimeter on 50 volt scale, check pin ... Jun 9 2012, 01:29 PM
Travis Neff Do you have a spare relay board? yours could be b... Jun 9 2012, 01:31 PM
Tom I have had these relay problems before and found o... Jun 9 2012, 01:58 PM
KaptKaos I am thinking I need to focus on the power supply ... Jun 9 2012, 02:07 PM
kg6dxn Before you get too deep. have you verified the fue... Jun 9 2012, 02:13 PM
KaptKaos Not getting power to the pump at all. I ran my me... Jun 9 2012, 02:25 PM
Travis Neff Is this a DJET engine? the ECU controls power to ... Jun 9 2012, 02:46 PM
KaptKaos Updated. See the top. Thanks for all of your h... Jun 9 2012, 03:52 PM
markb :Qarl:
Sometimes it really is that simple. :blin... Jun 9 2012, 04:18 PM
Tom Good job! I was hoping it was something simple... Jun 9 2012, 06:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:56 PM |
