> Relay is good. No power to fuel pump., Now what??
KaptKaos
post Jun 9 2012, 09:22 AM
Family
UPDATE: Self inflicted wounds are the worst. She's running.
So the other day when I was charging the battery, I knocked loose one of the 4 leads off of the positive terminal of the battery. I didn't know I had done it.
I am not sure what made me go check the battery, but as soon as I did, the wire dropped out.
Tom - I think that this is what your fuse box is for? Figures.
Thanks for all of your help.
Swapped in known good relay from headlight motor for fuel pump. No dice. No power to the fuel pump.
Fuses all look good. Going to replace the fuel pump one anyway.
Trans ground looks ok, but think I will double-check that.
Is there anything else I should be looking for?
Not sure if this is related, but a few weeks ago, my dash lights stopped lighting. The blinkers and idiot lights work, just not the illumination when the headlights are on.
I actually have some time this morning, and am going to try to diagnose my fuel pump issues.
Got a multi-meter, got some help to turn the key, and got a local VW store I can get a new pump or relay from.
So, which relay on the panel in the engine bay is for the fuel pump? I have a SirAndy Jumper in there (see his classic article).
Also, my multi-meter has ranges. Which setting should I use to test for power to the fuel pump?
Thanks in advance.
TravisNeff
post Jun 9 2012, 01:31 PM
Do you have a spare relay board? yours could be bad - that flowchart will help you pinpoint it. You can take the tar off the bottom & resolder to fix (if that's what the root cause is).
Check for the 3 grounds at the rear, top of the engine, & ground point under the relay board.
KaptKaos   Relay is good. No power to fuel pump.   Jun 9 2012, 09:22 AM
kg6dxn   :D   Jun 9 2012, 09:47 AM
KaptKaos   Thanks Mike!   Jun 9 2012, 09:55 AM
walterolin   KG6DXN beat me to it. The Haynes manual shows the...   Jun 9 2012, 09:58 AM
KaptKaos   Update in first post.   Jun 9 2012, 12:18 PM
Travis Neff   Try Brad anders DJET page, he has a fuel pump diag...   Jun 9 2012, 12:28 PM
KaptKaos   Try Brad anders DJET page, he has a fuel pump dia...   Jun 9 2012, 12:35 PM
markb   You started from the beginning, and spun all the f...   Jun 9 2012, 12:28 PM
KaptKaos   You started from the beginning, and spun all the ...   Jun 9 2012, 12:37 PM
markb   Do a quick search here for ground points. I'm ...   Jun 9 2012, 12:40 PM
Travis Neff   http://members.rennlist.com/pbanders/FPChecklist_f...   Jun 9 2012, 01:03 PM
Tom   With your multimeter on 50 volt scale, check pin 3...   Jun 9 2012, 01:04 PM
KaptKaos   With your multimeter on 50 volt scale, check pin ...   Jun 9 2012, 01:29 PM
Travis Neff   Do you have a spare relay board? yours could be b...   Jun 9 2012, 01:31 PM
Tom   I have had these relay problems before and found o...   Jun 9 2012, 01:58 PM
KaptKaos   I am thinking I need to focus on the power supply ...   Jun 9 2012, 02:07 PM
kg6dxn   Before you get too deep. have you verified the fue...   Jun 9 2012, 02:13 PM
KaptKaos   Not getting power to the pump at all. I ran my me...   Jun 9 2012, 02:25 PM
Travis Neff   Is this a DJET engine? the ECU controls power to ...   Jun 9 2012, 02:46 PM
KaptKaos   Updated. See the top. Thanks for all of your h...   Jun 9 2012, 03:52 PM
markb   :Qarl: Sometimes it really is that simple. :blin...   Jun 9 2012, 04:18 PM
Tom   Good job! I was hoping it was something simple...   Jun 9 2012, 06:32 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:55 PM
