ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
Hello all,
I've been meaning to look for an exhaust leak at the head for some time. I ordered new copper rings, but before I can install them, I need your advice on how to get the exhaust off. As you can see in pictures, the headers have been so boogered up, that it is impossible to fit a socket on some of the barrel nuts. Its like the whole thing has been bent sideways, which means the header is butted up against the barrel nut. One of them in particular is really an issue because for whatever reason I cannot reach the top of the stud. The barrel nut is so far down along the thread that there is nothing sticking out far enough to get a socket on. To make matters worse, while tinkering with it, I backed one of the barrel nuts off only to find the stud pulled completely out. Is it possible to insert a helicoil with the engine in the car once I get the exhaust off? Thanks for the help! Attached thumbnail(s) ![]() |
3d914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region ![]() |
Take it from experience, helicoils will not work for the exhaust - they'll pull after the first couple of heat cycles. Timecerts are the only way to go. Better yet, have the holes flood-welded and redrilled.
As far as getting the exhaust off. If you get get a couple of hex nuts on the protruding thread, you can back out the stud and all from the head. It may be easier if you drop the engine and can put it on a stand, rotate it upside down and work from there. That way any penetrating fluid you use won't roll down in your face. There are some shops that can deal with this cleanly - but they need experience with the Type IV. Good luck |
Lo-Fi Version | Time is now: 4th July 2025 - 12:01 AM |
