richardL |
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 27-January 03 From: San Diego, CA Member No.: 201 Region Association: None ![]() |
So my car ran the other day without problems. At first there seemed to be electrical issues, then they miraculously went away and now they are back.
Now its completely dead on the ignition switched circuits. The car has carbs and hence no FI, most of that wiring is removed. The battery is charged, the parking lights work and the instrument panel lights come on as well, the green parking light light as well. I thought there was a problem on the ignition switch, so I have a brand new race style switch. Power in, switched power out, starter out. With the ignition off I am getting around 13 volts at the switch. When I turn on the switch I get 0 volts. I disconnected all the three output wires (red, black and a thin red, which I think is for the voltmeter) and then I have 13V at the output terminal of the switch. If I connect any one of the three output wires again I get 0V. With them disconnected, if I try the starter, momentary switch the voltage goes to 0V - the starter doesn't try to turn or anything. I removed all the fuses, just in case, and it has no effect on the above symptoms. I also have an external kill switch and I always seem to have the expected 13V at the output of that, even when the ignition is switched on and doing nothing. I am confused, as any kind of connection seems to kill the voltage, yet the battery seems OK and can support side lights at least. Am I missing something obvious? Am I being dumb? How should I go about diagnosing this? Any suggestions would be very gratefully received. Richard |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Short, and has to be with something common. If your meter drops to 0V that means that the place that you are testing from and ground have the same electrical potential (they are electrically the same point).Next is to find where these wires are together. I suspect that the wires have been altered by the DAPO.
Lo-Fi Version | Time is now: 7th July 2025 - 01:46 PM |
