> Electrical Gremlins, HELP!!!
richardL
post May 29 2004, 01:46 PM
So my car ran the other day without problems. At first there seemed to be electrical issues, then they miraculously went away and now they are back.
Now its completely dead on the ignition switched circuits.
The car has carbs and hence no FI, most of that wiring is removed.
The battery is charged, the parking lights work and the instrument panel lights come on as well, the green parking light light as well.
I thought there was a problem on the ignition switch, so I have a brand new race style switch. Power in, switched power out, starter out.
With the ignition off I am getting around 13 volts at the switch. When I turn on the switch I get 0 volts. I disconnected all the three output wires (red, black and a thin red, which I think is for the voltmeter) and then I have 13V at the output terminal of the switch. If I connect any one of the three output wires again I get 0V. With them disconnected, if I try the starter, momentary switch the voltage goes to 0V - the starter doesn't try to turn or anything.
I removed all the fuses, just in case, and it has no effect on the above symptoms.
I also have an external kill switch and I always seem to have the expected 13V at the output of that, even when the ignition is switched on and doing nothing.
I am confused, as any kind of connection seems to kill the voltage, yet the battery seems OK and can support side lights at least.
Am I missing something obvious? Am I being dumb? How should I go about diagnosing this? Any suggestions would be very gratefully received.
Richard
richardL
post May 29 2004, 05:47 PM
The new wire cured it - fired right up (IMG:style_emoticons/default/smilie_pokal.gif)
Only briefly though as the fuel pump is powered off the accessory circuit and I hadn't connected that.
So... connect that up and then plumb the wire into place correctly and I should be in better shape.
Thanks for the help.
Richard
- Lo-Fi Version Time is now: 7th July 2025 - 01:49 PM
