| Dr Evil |
Jun 13 2012, 01:47 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,044 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
From my 31 pages of trans notes:
*Clutch cable The clutch cable being too loose is probably one of the most common reasons that people’s shifting sucks. If your cable is too loose then you will not be able to fully disengage the pressure plate from the clutch disk and you will keep power to the transmission. If it is really loose then reverse will grind when shifting into it from a standstill. There is no way that this should happen if the clutch is fully disengaged. To properly adjust your clutch, you need to tighten the cable until the clutch disengages at about 1/4 to 1/3 pedal travel (See figure 1 in appendix). If the clutch disengages too early then it is too tight, too late then it is too loose. Attached image(s)
Dr Evil If your clutch cable seems impossible to adjust, y... Jun 13 2012, 01:50 PM
Dr Evil Also, it is often that the replacement cable is to... Jun 13 2012, 01:51 PM
buck toenges
Also, it is often that the replacement cable is t... Jan 14 2019, 03:47 PM
jim_hoyland I was under the impression that the clutch should ... Jun 13 2012, 01:53 PM
Dr Evil
I was under the impression that the clutch should... Jun 13 2012, 02:09 PM
shoguneagle Good job, Doc.
I do everything the Doc has said b... Jun 13 2012, 02:02 PM
jim_hoyland So I need to tighten a little bit more so that the... Jun 13 2012, 04:27 PM
Dr Evil The floor stop is there to make sure you do not ov... Jun 13 2012, 04:52 PM
tomrev
The floor stop is there to make sure you do not o... May 20 2014, 03:04 PM
ClayPerrine Just an addendum to the evil doctor's commenta... May 20 2014, 03:13 PM
tomrev
Just an addendum to the evil doctor's comment... May 20 2014, 04:36 PM
JawjaPorsche Most people use aluminum tubing and have seen peop... Jan 14 2019, 06:56 PM
Dave_Darling One thing to note: The "helper" spring ... Jan 14 2019, 10:44 PM
MikeM Hi all...don't mean to hijack...
My clutch ped... Jan 15 2019, 10:48 AM
Bartlett 914
My clutch pe... Jan 15 2019, 02:24 PM
MikeM I removed the console, carpet and shifter. Tube in... Jan 15 2019, 04:58 PM
Bartlett 914
I removed the console, carpet and shifter. Tube i... Jan 15 2019, 05:17 PM
second wind
*Clutch cable
... Jan 15 2019, 11:11 PM
porschetub
*Clutch cable
... Jul 13 2022, 07:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th November 2026 - 03:00 AM |
