> Electrical Gremlins, HELP!!!
richardL
post May 29 2004, 01:46 PM
So my car ran the other day without problems. At first there seemed to be electrical issues, then they miraculously went away and now they are back.
Now its completely dead on the ignition switched circuits.
The car has carbs and hence no FI, most of that wiring is removed.
The battery is charged, the parking lights work and the instrument panel lights come on as well, the green parking light light as well.
I thought there was a problem on the ignition switch, so I have a brand new race style switch. Power in, switched power out, starter out.
With the ignition off I am getting around 13 volts at the switch. When I turn on the switch I get 0 volts. I disconnected all the three output wires (red, black and a thin red, which I think is for the voltmeter) and then I have 13V at the output terminal of the switch. If I connect any one of the three output wires again I get 0V. With them disconnected, if I try the starter, momentary switch the voltage goes to 0V - the starter doesn't try to turn or anything.
I removed all the fuses, just in case, and it has no effect on the above symptoms.
I also have an external kill switch and I always seem to have the expected 13V at the output of that, even when the ignition is switched on and doing nothing.
I am confused, as any kind of connection seems to kill the voltage, yet the battery seems OK and can support side lights at least.
Am I missing something obvious? Am I being dumb? How should I go about diagnosing this? Any suggestions would be very gratefully received.
Richard
David_S
post May 29 2004, 11:33 PM
QUOTE(Otmar @ May 29 2004, 04:45 PM)
First off, if it were really a short you'd be getting either smoke or a blown fuse. What you are looking at here is a high resistance connection. This connection looks fine until you put a load on it, at which time it measures much more like a open circuit.
This is what I was thinking also......broken wire, not shorted. Sounds like the wire is broken or not making a full connection at one of the terminals. I have seen this exact thing where a wire will have about 30 strands of wire and all but 2 or 3 strands are broken. The wire will carry 12 volts until you put a load on it and then it can't carry the amperage, so the voltage drops to 0. Could be wrong, but this is what I am guessing!
DavidS
- Lo-Fi Version Time is now: 7th July 2025 - 01:38 PM
