> sandwich oil cooler adapter and oil cooler questions
type47
post Jun 6 2012, 06:10 AM
Viermeister
After track sessions this past weekend, oil temps as indicated by a dipstick thermometer (Mainely Custom item) indicated temps of about 252 F after 20 minute sessions (ambient temps in the 60's). The engine is a Euro D-Jet with 20-50 Brad Penn. The engine that was in the car when I bought it (not the same engine as in the car now) has a sandwich oil cooler adapter and the oil cooler is still mounted on the car and I think I will hook it up again. Two questions; first is the indentification of the outlet and inlet on the adapter; which is which or how do I figure out which one the oil should exit from and which should the oil return. Second, on a radiator style oil cooler, do you hook it up so that oil goes in the "top" and filters/goes down the coils and exits out the bottom connection or goes in the bottom and pressure feeds up the cooler and exits out the top to return? TIA
tomeric914
post Jun 14 2012, 07:25 PM
One Lap of America in a 914!
That ball, cup and spring are the oil filter bypass. The oil was likely bypassing the cooler and the filter and going back to the engine.
I removed my spring, punched out an aluminum plug a thousandth or two larger than the hole, pressed in the plug and peened over the edge of the hole in a couple of spots.
It's in a thread I contributed to on oil coolers. Search and ye shall find.
pcar916
post Jun 15 2012, 07:54 AM
Is that a Lola?
QUOTE(tomeric914 @ Jun 14 2012, 08:25 PM) *
I'm an advocate of RTFM also but there are "billions" of oil cooler related threads. How about a few key words or a link to the thread? You know... for those of us who are busy too? (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 5th October 2026 - 07:18 PM
