Where do I buy these diet pills for my car? |
moggy |
Jun 6 2012, 04:02 PM
Member Group: Members Posts: 192 Joined: 15-December 04 From: Wales Member No.: 3,285 |
As some of you may know I rally a 914 over here in the UK. Mainly against Ford Escorts. Now I always knew that I was down 50bhp to the Escorts but I always thought I was lighter. At the previous rally my car, along with all other competitors, were weighed. My car came in 1010kg, with a full tank of fuel, driver and co-drivr were not in th car. The Escorts were all about the same.
So..... how do some of you guys get so light? Here's what I've already done to save weight: Lexan windows, side and back F/glass boot and bonnet All grill engine lid Removed heat shield above exhaust Stripped out interior including all sound deadening and tar Late doors but with the crash bar cut out. Here's what is fighting against the weight savings: Skid plates front and rear Front oil cooler and oil lines to it. Roll cage Engmann long kit CFR rear suspension mount reinforcement kit So.... alot of you guys have the additional weight of the above e.g. rollcage, rear suspension reinforcements etc. How do you get the car below 1000kg? what am I missing??? |
Gunther |
Jun 15 2012, 08:07 PM
Racer from birth Group: Members Posts: 50 Joined: 1-June 09 From: Charlotte, NC area Member No.: 10,429 Region Association: South East States |
I noticed that no one mentioned that little parachute in the back.
You dont go fast enough to effectively use a rear spoiler. (IMG:style_emoticons/default/sawzall-smiley.gif) Cut every little tang and bracket you dont need. replace all steel that you can with aluminium,CF or fiberglass. My 2cents. Good luck (IMG:style_emoticons/default/smilie_pokal.gif) |
moggy |
Jun 16 2012, 01:30 PM
I noticed that no one mentioned that little parachute in the back. You dont go fast enough to effectively use a rear spoiler. (IMG:style_emoticons/default/sawzall-smiley.gif) Cut every little tang and bracket you dont need. replace all steel that you can with aluminium,CF or fiberglass. My 2cents. Good luck (IMG:style_emoticons/default/smilie_pokal.gif) So how fast do I need to go to 'effectively' use a spoiler? I've had a few days break from the garage but back in there tomorrow to set on the dash area. Will give an update on the weight that's dropped off and maybe a picture of the metal that's been removed. Cheers Moggy |
SirAndy |
Jun 16 2012, 08:21 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
So how fast do I need to go to 'effectively' use a spoiler? For the rear of a 914 to get light at speed you have to go above at least 110 mph or even more, depending on your setup. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:26 PM |
