> Heater Pull Cable, Bent improperly?
Eric_Shea
post Jun 17 2012, 05:36 PM
PMB Performance
Hey Gang,
Installing the heater control cable and ran into a problem. Yes, I realize there is a left and a right (longer/shorter etc.) but, after trying both ways it appears the cable is bent wrong from the factory. I'm about 3.5" off each way.
Has anyone run into this in the past?
Too Short:
Too Long:
Eric_Shea
post Jun 17 2012, 06:14 PM
PMB Performance
So I'm not hallucinating from the brake cleaner fumes.
Maybe Bruce has an original...
Eric_Shea   Heater Pull Cable   Jun 17 2012, 05:36 PM
A&PGirl   That's the same as my new Porsche Cable. The o...   Jun 17 2012, 06:10 PM
Eric_Shea   So I'm not hallucinating from the brake cleane...   Jun 17 2012, 06:14 PM
A&PGirl   Maybe they used a batch of 911 cables and slapped ...   Jun 17 2012, 06:20 PM
JimN73   I had the same problem and ended up using some oth...   Jun 17 2012, 06:34 PM
Spoke   Are they equal lengths from the bend? Can you stra...   Jun 17 2012, 06:52 PM
Eric_Shea   I was successful in re-bending the original. Had ...   Jun 18 2012, 02:51 PM
tomeric914   I was successful in re-bending the original. Had...   May 18 2013, 09:39 PM
Cap'n Krusty   WHAT? If the long side was 3.5" too long and...   May 18 2013, 10:21 PM
Eric_Shea   WHAT? If the long side was 3.5" too long an...   May 18 2013, 11:29 PM
tomeric914   WHAT? If the long side was 3.5" too long a...   May 19 2013, 06:13 AM
jeffdon   Heat? Oh, All that stuff.   May 18 2013, 10:33 PM
Drums66   Heat? Oh, All that stuff. ......Go Heat,(Miam...   May 19 2013, 11:59 AM
mepstein   I had to rebend mine. Worked perfectly when the pa...   May 19 2013, 06:20 AM
JawjaPorsche   I had to rebend mine. Worked perfectly when the p...   May 19 2013, 09:10 AM
SLITS   I'm not that anal ... I just clamped the wire ...   May 19 2013, 09:37 AM
76-914   I'm not that anal ... I just clamped the wire...   May 19 2013, 10:30 AM
Eric_Shea   I'm not that anal ... I just clamped the wir...   May 19 2013, 02:04 PM
TJB/914   Hey, I am having the same problem with too long ...   May 19 2013, 10:37 AM
mepstein   Hey, I am having the same problem with too long ...   May 19 2013, 10:46 AM
TJB/914   Hey, I am having the same problem with too long...   May 19 2013, 11:10 AM
Jeff Hail   Hey Gang, Installing the heater control cable an...   May 19 2013, 10:48 PM
- Lo-Fi Version Time is now: 9th June 2026 - 02:27 PM
