> Lower Front Strut Ball Joint, Tapered Thread Stud removol
wndsnd
post Jun 21 2012, 10:43 AM
You wanted a horse, but got a goat. Nobody wants a goat....
(IMG:style_emoticons/default/headbang.gif)
I am really second thinking buying this car that lived in MAINE its whole life. Nothing is as it should be during dissasembly, and I am working with penetrants, heat, leverage, and will power and destroying almost everything coming off.
I am now on replaceing the front struts and am at the lower ball joint. The Hayes manual calls for a hex nut or taperd thread stud. I think I have the later after removing the nut from one side.
This stud I have map torched, and soaked with penetrant, and have pounded on with a mallet. looks like a little give on the other side but I don't think I am using the propers tools or technique. Any help or advise would be appreaciated... At this point it I am flatening the end of the stud.
John
wndsnd
post Jun 21 2012, 07:16 PM
I had no luck withe the heat. Now that I have the strut out and Rich explained it to me, I think I will have the local machine shop press it out so I don't damage the thrut end.
wndsnd   Lower Front Strut Ball Joint   Jun 21 2012, 10:43 AM
malaga_red75   John, I just did this during my 5-lug conversion....   Jun 21 2012, 11:22 AM
Dave_Darling   My wife's SC has the same style ball joint. I...   Jun 21 2012, 11:50 AM
seanery   so let me get this straight Dave, did you reuse th...   Jun 21 2012, 11:53 AM
FourBlades   Taking the a-arm off the car makes it easier to ap...   Jun 21 2012, 01:01 PM
rhodyguy   as fugly as that strut assem looks, i think you...   Jun 21 2012, 01:02 PM
wndsnd   The ball joint will have to be replace by the time...   Jun 21 2012, 01:29 PM
r_towle   You could take the lower nut off with a pipe wrenc...   Jun 21 2012, 02:07 PM
r_towle   oh, Once you pull it out, dunk the whole stru into...   Jun 21 2012, 02:09 PM
wndsnd   oh, Once you pull it out, dunk the whole stru int...   Jun 21 2012, 03:12 PM
jmill   I used an air hammer. You could also drill a hole...   Jun 21 2012, 02:58 PM
wndsnd   Not the greatest example of a person with patience...   Jun 21 2012, 03:09 PM
r_towle   ball joint is bolted from below the a-arm. Its abo...   Jun 21 2012, 03:26 PM
jmill   It looks like you have the correct replacement but...   Jun 21 2012, 03:54 PM
TargaToy   Also I had better luck cutting off the round cast...   Sep 25 2012, 05:54 PM
infraredcalvin   Also I had better luck cutting off the round cas...   Sep 25 2012, 09:44 PM
jmill   Oh, and then you'll need the special P tool to...   Jun 21 2012, 04:02 PM
wndsnd   Thanks guys, All great information and help. :b...   Jun 21 2012, 06:19 PM
Eric_Shea   Remember my email about the MAP torch. Let's t...   Jun 21 2012, 06:39 PM
r_towle   no special tools needed. put the strut housing in ...   Jun 21 2012, 06:49 PM
wndsnd   Rich Now this is making sense. I thought the rep...   Jun 21 2012, 07:03 PM
cwpeden   Ive always been a fan of the saying "Fire is ...   Jun 21 2012, 07:08 PM
wndsnd   I had no luck withe the heat. Now that I have the...   Jun 21 2012, 07:16 PM
jmill   You can use a pipe wrench, vice, chisel and a hamm...   Jun 21 2012, 07:41 PM
wndsnd   Nice!   Jun 21 2012, 07:46 PM
- Lo-Fi Version Time is now: 8th July 2025 - 09:44 PM
