JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
I have noticed a lot of 914's for sale lately on Ebay, Craiglist, and here on 914World that have carbs. I was wondering what prompted these owners to scrap their FI for carbs? As a original owner of a 914 I know you have to stay on top of the FI system with maintenance and tender care. Was it because some teeners exchanged owners so much that it was easier to switch to carbs than to chase the FI problem? Or was it because there is a shortage of capable 914 FI mechanics that understand the D-Jet system or L-Jet system? This is not a knock on teener owners that have carbs. (IMG:style_emoticons/default/blink.gif)
Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
After doing my engine swap from a 2.0 Djet to a 2056 w Ljet, I really have to say that trial and error is the only way to figger out some stuff. I have also found the Ljet to be a lot more simple, what with no trigger points, nor that mystical magical MPS... The main problems I had were 3 bad injectors, and a coupla vacuum leaks. Since then the car has run very well.
I still am not certain of the mixture, she seems to be running a bit rich, as I've gone through the exhaust for leaks, but I'm still getting some minor backfiring under decel in gear... To me, the best way to check was to crank the engine with the injectors removed from the engine and squirting fuel into small jars; I used some prescription vials. If you're not getting the appropriate amount of fuel, then start working back from there, which may include swapping injectors from one cyl to another... Then eliminate vacuum leaks... It's time consuming, but not that difficult. ** Be the fuel injection** (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 3rd July 2025 - 11:55 PM |
