Bullet |
Member ![]() ![]() Group: Members Posts: 116 Joined: 16-April 04 From: Newberg, OR Member No.: 1,940 ![]() |
I can seem to get my 914 to not run Rich. I have checked Injector spray paterns, replaced cap,rotor, points, condensor,plugs, plug wires. and belive that my vacuum routing is correct. I question the integrety of the MPS. if i remove the vacuum hose that runs to it and clamp it off i get no change at all in performance. I was told by a co-worker that i should drill out the riviots and check to see if it is gummed up. I just removed it and am getting ready to take it apart, when out of curiousity I ohm checked the teminals and this is what i got : pin 8 - pin 10 350 ohms, pin 7 - pin 15 90 ohms. is this normal? does anyone know of any way to check the MPS. Or could any one do a quick ohm check on theese terminals to let me know if that is a correct reading? any help would be greatly apreciated.
Bullet |
Thanks for the link. I was just surfing around on pelicanparts.com when i ran in to this: Fuel Injection Trigger Points
These are the trigger points that are located inside your ignition distributor. Often overlooked by owners when diagnosing your system, these points send the pulse to fire the fuel injectors. Replace your fuel injection points if you find that your injectors are not firing correctly. WHOA!!!! what the hell is this, were is this, does my car have this? |
Lo-Fi Version | Time is now: 8th July 2025 - 08:01 PM |
