> Help please....no start!
MikeM
post Jun 25 2012, 10:13 AM
Hi guys...
I have a no start condition on my 74 2.0 liter,D-jet.
Seems like the fuel pump is not running. As per my crappy manual, I have checked for power at pins 87 and 86 where the pump relay plugs in. There is no power at either pin with the key on. Manual says if that is the case, then start checking ignition wiring. Obviously, I'm missing something. Swapped out relays with no luck also.
Any help really appreciated....
Mike
Tom
post Jun 25 2012, 12:19 PM
Mike,
Before you go running wires here and there, try the following and get back to us.
1- check for power at pin #30 of the fuel pump relay, third relay from front.
if power, move on to #2
if no power, check the rear fuse just in front of the frontmost relay for power , both sides to ground for 12 volts. Power to either?
If you have power to the right side but not left side, check the fuse.
2- check for power to pin 85 of the fuel pump relay with the key switch to on. No power, check power relay, second relay back from the front.
Check these and let us know.
Tom
- Lo-Fi Version Time is now: 3rd March 2026 - 09:13 AM
