> MPS
Bullet
post May 31 2004, 12:23 PM
I can seem to get my 914 to not run Rich. I have checked Injector spray paterns, replaced cap,rotor, points, condensor,plugs, plug wires. and belive that my vacuum routing is correct. I question the integrety of the MPS. if i remove the vacuum hose that runs to it and clamp it off i get no change at all in performance. I was told by a co-worker that i should drill out the riviots and check to see if it is gummed up. I just removed it and am getting ready to take it apart, when out of curiousity I ohm checked the teminals and this is what i got : pin 8 - pin 10 350 ohms, pin 7 - pin 15 90 ohms. is this normal? does anyone know of any way to check the MPS. Or could any one do a quick ohm check on theese terminals to let me know if that is a correct reading? any help would be greatly apreciated.
Bullet
post May 31 2004, 01:26 PM
I read through his site and still come to the conclusion that it has to be my MPS. I have a verry rich run from idle to WOT. I have to drive it from my work to my house last night. only 3 miles but more then i wanted to with it running that bad on a new rebuild. the hole time of driving it it blew Black smoke out in huge clouds. according to that link you posded for me the OHM specs are good. and I am going to vacuum test it here in a bit once i find a pump to use. Mine is at work and they are closed today (IMG:style_emoticons/default/sad.gif) . if i fail the vacuum test were is the best place to find a rebuilt, for a reasonable price. I can do a dual webber kit for $800. so if i cant find a MPS for less then that I will be going with the webbers.
Bullet   MPS   May 31 2004, 12:23 PM
gklinger   Pretty much everything you could want or need to k...   May 31 2004, 12:34 PM
Bullet   Thanks for the link. I was just surfing around on...   May 31 2004, 12:38 PM
gklinger     May 31 2004, 12:59 PM
Bullet   I read through his site and still come to the conc...   May 31 2004, 01:26 PM
mike_the_man   First of all, pull a vacuum on the MPS. I bet th...   May 31 2004, 01:29 PM
Bullet   Well it looks like i wil have to wait untill tomor...   May 31 2004, 02:36 PM
mike_the_man   Not much you can test with the trigger points, as ...   May 31 2004, 03:43 PM
pbanders   Rich running can have several causes. First thing ...   May 31 2004, 04:06 PM
pbanders   If your car has over 100K miles and you don't ...   May 31 2004, 04:07 PM
Bullet   ...   May 31 2004, 06:01 PM
pbanders     May 31 2004, 06:21 PM
Bullet
  May 31 2004, 06:33 PM
tod914   Goes right behind the Heat level inbetween the 2 s...   May 31 2004, 06:40 PM
lmcchesney   Brad has given you the method of checking the vacu...   May 31 2004, 08:06 PM
bob174   I saw some advice about adjusting the mixture with...   May 31 2004, 08:35 PM
Bullet     Jun 1 2004, 01:04 AM
tod914   That's it. That defrost cover has a baseplate...   Jun 1 2004, 08:14 AM
Bullet
  Jun 1 2004, 07:41 PM
Bleyseng   All MPS's are basically the same. Some are sho...   Jun 1 2004, 07:55 PM
4WheelDrifter   L McC, I didn't mean you listed the auction, j...   Jun 1 2004, 11:02 PM
lmcchesney   My email was lighting up with questions.   Jun 2 2004, 06:21 AM
Bullet   Well, I won the auction for the MPS. recived it i...   Jun 10 2004, 11:00 PM
dmenche914   there are different MPS for different years, and e...   Jun 11 2004, 12:40 AM
dmenche914   Valve adjustment ????, compression test???? Is the...   Jun 11 2004, 12:47 AM
Bullet   It is a fresh rebuild. I adjusted the valves when...   Jun 11 2004, 01:06 AM
pbanders   What does the vacuum gauge guide tell you about a ...   Jun 11 2004, 09:43 AM
nebreitling   you have replaced the trigger points, no? do it i...   Jun 11 2004, 09:48 AM
mike_the_man   Have you tested all of the injectors to make sure ...   Jun 11 2004, 10:18 AM
Bullet   What i came up with, Even though Injector #3 does...   Jun 11 2004, 08:52 PM
lmcchesney   You are getting there Bullet. Just a little more....   Jun 12 2004, 12:44 PM
Bullet   Im about to give up on this car. It has to have a...   Jun 13 2004, 06:18 PM
Bullet   I jsut went out side and fired it, Noticed that wh...   Jun 13 2004, 06:50 PM
Bullet   I was reading through some stuff on pbanders site ...   Jun 13 2004, 08:44 PM
Bleyseng   It goes to the plenum via a rubber boot that has a...   Jun 13 2004, 10:21 PM
Bullet   I also just discoverd that if i remove the Yellow ...   Jun 13 2004, 10:35 PM
RustyWa     Jun 13 2004, 11:25 PM
Bullet   mine is a 75 2.0L. So you are saying that it goes...   Jun 13 2004, 11:43 PM
Bleyseng   Air cleaner then if you have a 75 with all the smo...   Jun 14 2004, 08:18 AM
RustyWa   ...   Jun 14 2004, 08:20 AM
RustyWa   I need a reminder. The MPS has no effect on the I...   Jun 16 2004, 01:07 PM
Jeff Bonanno   a quote from pbanders site (MPS page): "The LVT, ...   Jun 16 2004, 01:43 PM
pbanders   The basic injection pulse width at idle is still d...   Jun 16 2004, 04:18 PM
Bullet   So is that a yes or a No? does the MPS have an ef...   Jun 16 2004, 06:58 PM
Bleyseng   Only a leaky MPS has an effect on the idle as it s...   Jun 16 2004, 08:09 PM
Bullet   I dont think that the cam would have much of an ef...   Jun 16 2004, 08:21 PM
Bleyseng   There is no way to accurately set the A/F without ...   Jun 16 2004, 10:13 PM
Bullet   I have access to a 5-gas machine at work that i wa...   Jun 17 2004, 12:24 AM
Bullet   today a bummed a known good MPS that a co-worker h...   Jun 17 2004, 08:36 PM
lmcchesney   Glad to hear you isolated the problem to the MPS. ...   Jun 18 2004, 06:22 AM
- Lo-Fi Version Time is now: 8th July 2025 - 08:16 PM
